389 Tripower Swap
Old May 29, 2004 | 07:16 PM
whitedawg99's Avatar
Car: 83 T/A
389 Tripower Swap
Kicking around idea of swapping a 389 tripower into an 83 T/A. Indian Adventures has mounts and headers, been told 200-4R will mount right up to it. Has anyone tried this and what kind of problems did they run into. Not looking to burn up any strips just a crusier. Thanx
Old May 29, 2004 | 09:23 PM
ede's Avatar
ede
think if i had a 389 w/tri power i'd sell it to someone that needed it and then buy a crate engine from GMPP.
Old May 29, 2004 | 10:19 PM
brdofpry85ta's Avatar
Car: 1985 Trans Am
Engine: 6.6 at least
Transmission: T-56 (waiting)
Axle/Gears: 9" w/4.56 & spool (4 now)
I heard that you would have to notch out the engine cross member (cant remember what it's called ). cause I asked a friend about a pontiac 400 swap...
Old May 29, 2004 | 11:25 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
It's called the K-member.
And that swap would be a nightmare. Stick with the small or even big block chevy.
Old May 29, 2004 | 11:27 PM
TexasLT1's Avatar
Car: '92 RS
How do you figure that? From the sounds of it he already has a 200R4, all he needs is the mounts and headers. Whats so complicated about that?
Old May 30, 2004 | 06:31 AM
ede's Avatar
ede
for one thing having a 200r4 doesn't get you very far since it wouldn't have the BOP pattern. you'd need to figure out the torque arm. motor mounts, trans cross member, exhaust then there would be the things that may or may not be a problem, like the k member, stearing box, heater box, and just about everything else under the hood would have to be looked at and considered. there are a lot of other swaps that would be easier and cheaper. nothing that couldn't be over come but for the time, effort ,and expense is a 389 tri power thirdgen what you really want?
Old May 30, 2004 | 08:12 AM
ljnowell's Avatar
Probably not the best option. Ede, his 2004r could have the BOP pattern, couldnt it? I had an 81 olds with a 307 olds in it, and it had a 2004r. IF he has one of these, it should work.
Old May 30, 2004 | 11:32 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
i had a 61 pontiac catalina with the 389 in it it would make for a fun ride if you can get it in there without too much trouble they are some real torqey engines but i think i would do as ede said and sell it to someone for some good $$$$$ then buy a good stout engine that would fit inthere a little bit easier ...but then agian the awe factor is unbelieveable when you pop the hood and find a 389 tri power under the hood of anything ..lol
Old May 30, 2004 | 12:52 PM
ede's Avatar
ede
yeah i guess the 200 could have the BOP pattern, way i took it he had a 200 from a f body.
Old May 30, 2004 | 01:05 PM
ljnowell's Avatar
AHH, if thats the case, its useless for him!
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
