LS1 - LT1 Swap Weights?
Old Jun 10, 2004 | 07:57 PM
Adrenaline's Avatar
Car: 92 Camaro RS
Just wondering for you swapers, what your car weighed before and after.
So how much did the LT1 add or drop, same with the LS1, the 6 speed, ect.. ect.. just wondering what the difference is after the swap. (obviusly the power is worth the weight gan :-D )
Old Jun 11, 2004 | 01:45 AM
FLYNLOW92rs's Avatar
Both the LT1 and LS1 weigh less then a SBC
The LS1 is about 150 pounds lighter, and it raised my car about .5-1"
The LS1 is an all aluminum engine
As far as weights are concerned, for a general estimate on stock engines it's like this......
SBC>LT1>LS1
Old Jun 11, 2004 | 05:40 AM
Adrenaline's Avatar
Car: 92 Camaro RS
Any actual weights.
anyone weigh there cars?
thank you tho, flynlow
Old Jun 11, 2004 | 11:03 AM
Originally posted by Adrenaline
Any actual weights.
Umm, I don't think anyone with an LS1 has weighed there car before and after.....But you take a the stock weight of your car just minus 145-150 pounds from it.......Maybe some with an LT1 will chime in and tell what their car weighs....
For reference
The LT1 is approx 80-90 pounds lighter then your average thirdgen engine, and the LS1 is 65-70 pounds lighter then your LT1
Is there a specific reason you are looking for actual numbers?? Prehaps we can help in other ways since weighing your entire car is not something that gets posted often
Old Jun 11, 2004 | 07:08 PM
Adrenaline's Avatar
Car: 92 Camaro RS
i was jsut curios what the weight gain/drop would be if i ended up doing the conversion. It looks like im just gunna have the motor i built (355) shiped to me, and ill look for a T-56 to swap in all at the same time.
is a 350 heavier or lighter than the 305 TBI
how do you go about moving the center of gravity, ect. i want the car to handle like its on rails. i have a lot of work to do first, but i just like to look in the long run...
Old Jun 11, 2004 | 07:16 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Most Gen 1 motors will wiehg about the same, so your 305 TBI and 350 will be about identical. A 305 block is a hair heavier but not by much. Lowering your car is a great way to change the center of gravity.
Old Jun 13, 2004 | 01:03 PM
Drastius's Avatar
Car: 1985 Camaro Z28
Engine: Caprice LT1
85 Camaro Z28, Caprice Iron Head LT1, 4L60 E transmission, 3/4 tank of gas.
3380 pounds.
Old Jun 16, 2004 | 03:34 PM
Drakar's Avatar
3380 pounds.
W/driver or w/o?
Old Jun 16, 2004 | 04:15 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
3380 pounds.
Nice that must mean mine must be lighter than that. Don't auto trannies weigh 145+ lbs. I also have aluminum heads so I must be in the 3200 range.
Old Jun 16, 2004 | 06:55 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
SBC>LT1>LS1
LT1's and LS1's are SBC's
but anyway, LT1's wouldn't nessicarily weigh any less than a GENI SBC. there are plenty of GENI's that have aluminum heads, and in that case, the weight difference is probably none existant.
Old Jun 17, 2004 | 03:10 PM
Drakar's Avatar
The amount of aluminum headed FACTORY SBC 1's has got to be far far less then the amount of IRON headed ones, but basically you can look at it this way.
L98/LB9> LT1 > LS1
and that being all F-body ones, you throw in a B-body LT1 like me and you get ..... IRON Heads which almost negate any weight savings ..... basically Im saving a bit on the Intake vs my old iron LG4 intake.
Old Jun 17, 2004 | 05:08 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
T56's weigh about 138 alone.
Old Jun 17, 2004 | 05:26 PM
pasky's Avatar
I shoved it on a scaled here, was 123.4 lbs. Suck it.
Old Jun 17, 2004 | 06:20 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Sure you did, silly homo, you probably drained it for a few hours just to be able to claim it was lighter. Not to mention your scale is probably off
Old Jun 17, 2004 | 06:23 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
who cares? its like 10 pounds difference, you could get almost that by not eating the whole day.
Old Jun 17, 2004 | 06:42 PM
pasky's Avatar
Yea, 3.8 quarts of liquid is gonna push on 20 lbs. Then again, every scale in florida is the most accurate, hell every clock for that matter and the most important thing I forgot, your word is almighty.
EDIT: A 4L60E weighs about 200 #'s.
Old Jun 17, 2004 | 07:43 PM
pasky's Avatar
Just did some research, just about everywhere i check the weight of a T-56 comes out to 125 #'s.
BTW, think I found a picture of z28*****, maybe this is why yours weighed "138". Stop riding that shifter!!!
Old Jun 17, 2004 | 09:22 PM
Drastius's Avatar
Engine: Caprice LT1
Yea 3380 without driver
Old Jun 18, 2004 | 04:47 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
3296 shipping weight
1945 front
1351 rear
60/40 ratio in 82 but after a tank of gas and driver things could shift a bit
(just found rpo list today has the front/rear breakdown on it, compared it to my invoice "SW")
this is the weight with the lg4 and auto tranny and quite a few options
Old Jun 18, 2004 | 05:08 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Just for reference, a typical SBC weighs around 500lbs.
Old Jun 18, 2004 | 06:40 PM
splitting hairs.....
I think 99.9% of the board was able to interpret what i was saying.....
Old Jun 18, 2004 | 11:17 PM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
the pic of that guy riding that trans has me is the funniest thing I have seen in a while. And every post by pasky has me laughing my **** off.
Old Jun 19, 2004 | 09:24 PM
pasky's Avatar
*shrug*, he is the type of guy to tell you what is best and its his way or the highway so he treats everyone as if they have a lower intellgence when its him with the I.Q. you can trip over, prove him wrong and he makes some dumbass excuse like the one you saw above about my scale being off .
Old Jun 20, 2004 | 02:17 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
If an lt1 or ls1 was swaped into a v6 thirdgen would you need to replace the shocks?
Old Jun 23, 2004 | 11:29 PM
pasky's Avatar
If thier worn. I'd be more worried about springs.
Old Nov 29, 2004 | 10:46 AM
Peteracer's Avatar
I am running a SCCA car with a Gen1 SBC , with aluminum intake,heads,water pump and underdrive billet pulleys.
and a muncie M-21 transmission with aluminum bellhousing.
I wonder If i could save some weight swapping this set up If i swap in a LS1 backed with a T-56.
I know the LS1 is lighter, and the T-56 is heavier, I dont want to run a muncie with a LS-1 .
Can someone tell me if there is any weight savings according to their experiences
Peter
Old Nov 29, 2004 | 05:36 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Peter
An LS1 weighs 100lbs less then a aluminum headed Gen I or II motor. Even if the T56 leaves you with the same weight it will be much closer to the center of the car.
customblackbird
Aug 15, 2021 10:16 PM
1984HO
Mar 19, 2021 11:59 AM
lt1z350
Aug 28, 2015 05:57 AM
NBrehm
Aug 25, 2015 11:49 PM
sreZ28
Aug 14, 2015 07:48 PM
