how much $/time for v6-v8?
Old Jul 20, 2004 | 08:10 PM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
Looking at an 86 Sport Coupe w/ 5 speed, 450 bucks runs needs windshield and has small amount of rust on one fender, interior is in great shape, as is most of exterior...hardtop...new tires...
anywho, i figure the price is certianly right, the guy lives like 5 minutes from my house and its been sitting there for years, so i'll probably buy it as soon as i sell the cadillac.
Curious to know how much time the v6 to v8 swap takes, assuming you have a v8 donor car? How much does it usually end up costing?
Any sites with walk-through pics or whatever?
Old Jul 20, 2004 | 11:23 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
This one at the top of the page. Theres a sticky.
Took me and a friend like 6 hours. Mounts are the hardest part of the swap.
Cost can vary greatly depending on may things.
Old Jul 20, 2004 | 11:29 PM
yeah, i read the sticky, but it didnt touch on time and or cost....
i'd be doing lt1 if it has any effect on it....lol
Old Jul 20, 2004 | 11:38 PM
br()bert's Avatar
Car: 85 firebird
Uhm, iirc pasky has a lt1 in his orig v6 car. You might wanna try pmin him and asking a few q's.
My swap was a tpi motor converted to carb while still out of the carb. The swap did cost all that much really and was SOOOOOOOOOOO worth it.
Old Jul 21, 2004 | 09:12 AM
ljnowell's Avatar
Well, I have spent around 3k, and took about 6 months to get it right. But I did not work around the clock, only when I had the time. Realistically it could have been done in a few days, but I wanted to take my time and do everything right. As far as the cost, I could have spent less, but when I pop my hood, everything, minus the ps pump and pulleys is brand new.
Old Jul 21, 2004 | 11:44 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
There are a lot of variables, so cost/time weren't included in the general information.
For instance, I started with a carb car and ended up with a carb car. If either is FI, or you go to/from carb/FI, you've got the added complexity of dropping the tank to install/remove the in-tank fuel pump. That alone can eat up a good part of the 6 hours br()bert is claiming, or at least spend some time installing an adjustable pressure regulator if you stay with the in-tank and go carb (probably wiring issues to deal with, too).
Emissions/non-emissions is another variable. I did full emissions, so it took longer. If you're doing an LT1, you're going to have to figure on full emissions, because emissions and controls are pretty much tied together. Conversion to non-CC carb, as a lot of swappers do, is the "easiest" and "quickest" way to get the V8 running. However, it is never legal for use on public roads within the United States (although about half the population can get by with it). Some cars in some places can qualify for special plates (collector in Colorado), or limited use, so can be exempted from emissions.
Changing the front springs or not is a variable (some who did the swap didn't). If you don't, the V6 springs will bottom out and handling isn't very good, but you don't "have" to change them out when doing the swap. If you do the right thing, you're looking a few hours to get that done.
Condition of each car is a variable. My donor had been rear ended (really, really hard), so most of the exhaust wasn't usable, and I had to find another (and modify it to fit what I could use from the donor car). That alone took almost the 6 hours that br()bert is claiming. The donor apparently had been run into a curb or something when it was rear ended, which tweaked the radiator, so repairing what had been bent/cracked and chasing down the resulting leak took me several hours.
Year difference between driver-receptor/donor car is a variable. Mine were '82/'86, respectively, and they changed some of the harness connectors (kick-panel pass-through for the ECM connector was a different size; I did the whole dash harness, the connector to the back chassis changed completely, requiring splicing). That alone took a lot more than the 6 hours br()bert is claiming. If one is a Camaro and the other is a Firebird, that can cause additional problems (tach, for instance).
I bought the driver-receptor car in early May. I bought the donor car in early June. I drove the car for the first time in late August, not having worked on it each day in that time, but most evenings and what I had to myself of weekends. I didn't have any help, did it all myself.
Cost: I had about $1500 in it when I took the first drive, probably have $6k in it now with windshield, paint, engine & tranny mods, wheels/tires. Still need about $3k more to get it where I want it.
Old Jul 21, 2004 | 11:55 AM
br()bert's Avatar
Car: 85 firebird
____________________________________________
The 6 hours br()bert is claiming was just for the v6 to be pulled and the v8 motor and trans to be put in, the next day i put the dist,wires,carb,afpr in. Still in all i have like 9 hours into the swap from pulling the v6 to driving the v8.
Wiring issues? nah, i ran the ops wires to the ops on the v8. Fuel pump never missed a beat.
______________________________________________
You DO NOT have to change the front springs this is bs, the car will NOT bottom out, i have driven my car over 400 miles since the swap around three states and have had 0 problems, the car actually corners better then before, the front is about an inch lower then before, maybe 5 7's springs were whooped. Check this site, theres several people who have done the swap and did not change the springs. Seems the only reason this myth stays is because of the sticky.
__________________________________________________
Dont be a bonehead. Go to autozone, buy a new y pipe, its $80 .
And my rad was new.
____________________________________________________
__________________________________________-
I have yet to fix my speedo issue. Once i do thought im positive it wont take more then 6 hours. lol
Biggest time comsumer for us was the motor mounts. We had the v6 motor/trans out within 1.5 hours. Mounts too long because we didnt cut them off or drop the a arm as others did.
Old Jul 21, 2004 | 12:01 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I have no problem with bottoming out on my vehicle with V6 springs. I think that is a myth. You can see the clearance on the springs in my signature. I still have the stock shocks which aren't doing jack and it isn't bad. If I replaced the shocks im sure the car would handle much better. I do want to eventually get some drag springs though.
Old Jul 21, 2004 | 12:06 PM
br()bert's Avatar
Car: 85 firebird
Exactly, a myth. I wonder how many others have not changed the springs also. I know of a few.
Old Jul 21, 2004 | 12:14 PM
ljnowell's Avatar
I didnt change mine, but i do seriously need some new struts
Old Jul 21, 2004 | 12:51 PM
pasky's Avatar
Yea, thats my problem .
Old Jul 21, 2004 | 03:03 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
10,000 and springs were no problem...but...they were in good shape.
Old Jul 21, 2004 | 03:15 PM
Engine: 406
28" hoosiers &weld wheels...next to my 16's on my 4rth gen z28
Attached Thumbnails how much $/time for v6-v8?-p6280014.jpg
Old Jul 21, 2004 | 03:24 PM
Engine: 406
Gotta love the heartland!!!
Attached Thumbnails how much $/time for v6-v8?-p6280002.jpg
Old Jul 21, 2004 | 04:04 PM
five7kid's Avatar
It was my experience.
The car had new springs all around before the V6 block cracked (inadequate antifreeze mix). I left them in when putting in the V8, thinking since they were new I might not have a problem. I had the problems described. And I put in new struts b/4 I drove the car (same struts still in there 5 years later).
If you swap in a lighter engine (such as one with aluminum heads) or delete AC and such, you may indeed have no problems with the V6 springs.
Old Jul 21, 2004 | 04:05 PM
pasky's Avatar
That may explain it, I kept AC, but I do have aluminum heads. I don't think Brobert does though.
Old Jul 21, 2004 | 04:17 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
i have no big issues with the front v6 springs. except when i reinact The Dukes of Hazzard stunts .
ill soon replace them. i also do not have AC.
Old Jul 21, 2004 | 05:24 PM
br()bert's Avatar
Car: 85 firebird
Nope wish i did though (alum heads) maybe one day i will.
I also dont have ac or any smog crap. Come to think of it, i dont have heat right now ! My heater core blew like last month. I'll replace it before winter. No need for it in 80* weather.
platynumx
Apr 16, 2013 07:16 PM
kelham
Feb 24, 2008 11:16 PM
tourville
Interior Parts Wanted
Nov 6, 2006 09:48 PM
tourville
Oct 27, 2006 05:40 PM
