My 383 almost in!!! Check out the pics
Old Jul 26, 2004 | 12:26 AM
daddy33's Avatar
Car: '85 Camaro
I got my 383 together now and just need a couple more things to swap out my old 305 and put this one in. Im getting the ignition accessories this week and a Demon carb next week, all the pulleys are just swapping over from the 305. I'll keep you guys posted for more pics when i getting more things rolling......
daddy33's Avatar
Car: '85 Camaro
another pic
another pic from the side
Old Jul 26, 2004 | 12:27 AM
daddy33's Avatar
Car: '85 Camaro
pic
heres a pic from top
Old Jul 26, 2004 | 03:11 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
Looks familiar
Old Jul 26, 2004 | 11:45 AM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
Looks sweet from this end..
Old Jul 26, 2004 | 12:47 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
very nice
Old Jul 28, 2004 | 12:59 PM
MdFormula350's Avatar
nice.:rockon:
Old Jul 28, 2004 | 02:37 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Sweet setup. Is that going to fit under your stock hood or have you already worked that out?
Old Jul 28, 2004 | 04:26 PM
mike88form350's Avatar
Car: 88' Formula 350
Engine: 358 ci TPI
Transmission: Tremec T-56
looks sweet, nice build up man. Are those the GM roller rockers? post pics when you get it in the engine bay.
Old Jul 29, 2004 | 02:10 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
in about 12-15hrs from now I'll find out if an Air Gap fits under a stock 92 RS hood and let ya know later at night
Old Jul 29, 2004 | 07:27 AM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
I was going to ask you if that was an air gap. Should kick some tail when it's done.
Old Aug 4, 2004 | 10:04 AM
daddy33's Avatar
Car: '85 Camaro
yeah i think it should clear my hood with no problems, i have a 4 3/4" cowl hood so thats why The roller rockers i believe are crane 1.6 full rollers. Today i get to have a field day with parts. Im going to recieve my oil pan, distributor, water pump, fuel pump, msd wires, and torque convertor. So hopefully by the end of this week i could have it installed and i will post pics as soon as i can. I cant wait till its in!!!!!!!!!
Old Aug 4, 2004 | 11:57 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Just how are you going to get that past the Smog *****?
Just wondering....
Old Aug 4, 2004 | 12:28 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
Just wondering....
With good tuning(conservative timing), vacuum secondaries a cat and a friendly cam(220 duration under 500 lift) it really shouldn't be a problem for him. I chose an XE284 so I may be in trouble but I dont have to worry for a couple years What cam are you using anyway Daddy33?
BTW, the Air Gap fits fine under a stock '91 RS hood using stock engine mounts and a holley street avenger
Old Aug 4, 2004 | 12:42 PM
five7kid's Avatar
That's fine if all you have is a sniffer.
But, in California they have this nasty habit of opening the hood.
Old Aug 4, 2004 | 01:56 PM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Looks GREAT!!! Excellent choice of heads. What size are those AFR's? Are you going run a mild tune to pass emissions?
What Demon carb did you go with? I'm at a toss up between a holley DP and a speed demon and I'm wondering why you went with a Demon over a Holley?
Good luck with the engine!! Track times....
Old Aug 4, 2004 | 03:30 PM
ljnowell's Avatar
Have to agree with five7, you may have a hell of a time getting past the visual inspections. YOu may have to try and bribe someone.
Old Aug 5, 2004 | 12:01 AM
daddy33's Avatar
Car: '85 Camaro
well smog shouldnt be a problem, my ex's father knows how to pass people and has been doing it to his friends so....well im sure you get the point as far as the cam goes I'm running a Lunati 07103, 295 duration and 245 @ .050 with .534 lift but im got 1.6 RR so around .560 The AFR heads are 195cc and i won a 850cfm Demon carb for only $270. I just went with Demon because of the recommendation by the people i talk to and also like the way they look!!
Tonight i put just about all the parts on the engine except for carb which im still waiting to get and the oil pan (i got the oil pan today but summit sent me the wrong one ) 2morrow or Friday ill post up some pics of where im at right now
Old Aug 5, 2004 | 04:09 PM
305Tiger's Avatar
Car: 1987 Trans Am
Engine: LG4 305 w/emissions & A/C delete
Transmission: "...check!"
Axle/Gears: it's crap...they're stock!
holy...
...CRAP! May i just add, that I envy you! sweet job! Looks GREAT!
you betta post some pics, I need more screen saver & desktop pics! hehe!
-G
Old Aug 6, 2004 | 02:10 AM
daddy33's Avatar
Car: '85 Camaro
here are a couple more pics of some more stuff added on. Im still waiting for my Moroso oil pan and demon carb. Also im probably gonig to get some little chrome accessories to shine it up some. I was going to paint the pulleys the high temp aluminum color but thought the gloss black would break it up some. Once the other items come in though i will take another pic of it "complete" before i put it in my beast.
Old Aug 6, 2004 | 02:12 AM
daddy33's Avatar
Car: '85 Camaro
heres another pic
Old Aug 6, 2004 | 02:13 AM
daddy33's Avatar
Car: '85 Camaro
and another......
Old Aug 7, 2004 | 11:40 AM
daddy33's Avatar
Car: '85 Camaro
here is a shot of my car which the engine will be going in....
Old Aug 9, 2004 | 02:28 PM
Tobias05's Avatar
sweet!
EDIT:...didn't realize i had already replied to this topic...
Old Aug 9, 2004 | 03:41 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
wow, that is a gigantic hood!
i think that you are going to have a whole lot of fun with that combo! what are you doing for tranny/rear?
Old Aug 9, 2004 | 05:27 PM
five7kid's Avatar
Just making sure everyone understands that TGO in no way endorses such an approach.
Old Aug 9, 2004 | 07:04 PM
daddy33's Avatar
Car: '85 Camaro
five7kid i understand where your coming from and know that TGO doesnt endorse such an approach. I mean if all else fails, my father and i can turn it into a drag/show car and keep it at home. But till then this baby is going to be my weekend warrior.
yeah the hood is kinda big and takes a little time to get used to it but now i got the hang of it. I think it makes the 3rd gens look awesome though! It's only a 4 3/4" cowl.
As for my tranny its a 700r4 and has been professionally rebuilt about 6 months ago with high performance parts and was told to stand 600hp/600tq with no problem. I will also be putting in a TCI 3500 L/U converter once the motor is in.
The rear is still the stock 10 bolt GM posi with 3.73. This is the only thing thats going to worry me for holding that power
Old Aug 14, 2004 | 08:37 PM
daddy33's Avatar
Car: '85 Camaro
here are some updated pics.....
the old LG4 that finally gave.....
Old Aug 14, 2004 | 08:39 PM
daddy33's Avatar
Car: '85 Camaro
man i need some cleaning to do!
Attached Thumbnails My 383 almost in!!! Check out the pics-emptyenginebay.jpg
Old Aug 14, 2004 | 08:40 PM
daddy33's Avatar
Car: '85 Camaro
getting ready to set it in
Attached Thumbnails My 383 almost in!!! Check out the pics-enginegoingin.jpg
Old Aug 14, 2004 | 08:44 PM
daddy33's Avatar
Car: '85 Camaro
ok here is where im at right now. i just got done bolting the bellhousing and now im going to take a day rest. The fun part now putting the hooker 2210 in but these darn metal lines (i think tranny cooler lines?) are in the way. Anyways ill keep you guys posted
Old Aug 16, 2004 | 01:39 AM
84 Restore's Avatar
Car: 1984 Z28 camaro HO Gun metal Gray
Engine: 305,L69 H.O. rebuilt
Nice... very nice
Daddy33 this may be a little off topic but i noticed by your pic the engine bay is very clean. Did you do anything differnt to get like that other that degresser and elbow greese. I though I would ask and give u prasie for cleaning that area up. Most ive seen are as dirty as when the motor first came out. Nice job:hail: :hail:
Old Aug 16, 2004 | 05:16 PM
daddy33's Avatar
Car: '85 Camaro
well when the engine was out i just hopped in the engine bay and sprayed some degreaser and wiped it down. I let it all dry up and then spryed some of the areas with high temp gloss black paint. I still got more to prep up. Hopefully by the end of this week i should have some more things done. Its just hard right now because school started up for me and i dont have much time
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Mickeyruder
Sep 2, 2015 02:45 PM
LT1Formula
Aug 20, 2015 09:36 PM
sreZ28
Aug 14, 2015 07:48 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
