pics of the Hawk's LS1 k-member
Car: '89 rs convertible
Engine: ls1
Axle/Gears: 3.73 posi
many of you requested pictures of this when i got it so here's some pics of the Hawk's LS1 k-member , lightweight does not even begin to describe it . the powdercoat was very nice and this thing can't possibly weigh more than 20-30lbs.the main thing for me here was the fact i did not have to notch the old k-member and it just looks soooo tricky! i'm pretty sure i'm gonna have to buy front lowering springs due to the weight of this and the LS1 so my convertible doesn't look like a 4X4 a mile high in the air! close in design to the 4th gen BMR k-member , i like it.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Very interesting - any idea in the weight difference between that and the stock one?
I was thinking of how much weight you are pulling off the front end - 150lbs for the motor and maybe another 50lbs for the new member and suspension.... sweet
Engine: ls1
yup , i gotta have the tubular A-arms as well, i heard claims up to 200 lbs. weight reduction , i'm really not sure how it will be. the LS1 is about 100 lbs lighter than a cast iron small block so the car should definitely be a lot lighter.
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
:hail:
reminds me of something i gotta order pretty quick
hope it works with long tubes...
anychance you could bolt it up to the engine and take some pics
id really love to see what kinda clearance it adds
id really love to see what kinda clearance it adds Trending Topics
Post those pics of the k-member on the engine, be interested to see if you have clearance for long tube headers after installing that k-member......
How long was the wait, or was it delievered right away?
Engine: ls1
he didn't have it in stock in the red but i stil got it in about 3 weeks from ordering it and this was with me mailing a money order so it was reasonably quick.
the LS1 is really that much lighter?
you mean 100lb less compared to an iron block, head, intake, exhaust manifold small block?
I know it has a plastic intake and it is all aluminum, but it has that deep skirted cross bolted bottom end, then those "pushrod box" things in the valley.
a Bowtie aluminum SB (just the block) is only about 80-90 lb lighter than an iron "equivalent," and that's when it isn't an extra-thick heavy duty one.
did you weigh them? both with accessories/whatnot?
Car: 89 Firebird Formula
Engine: Custom Forged 402ci LS2 w/STS Turbo
Transmission: T56 6-speed
Axle/Gears: Moser 9" with 4.11
I haven't weighed mine, but the LS1 is supposed to be MUCH lighter than the Gen I Small Blocks or the LT1s.
I've got the Hawk's K-member as well, although I got it in black. I ordered it right off the website, had it show up about a week and a half later.
We'll be taking the stock k-member out of mine in the next week or two. I'll weigh up that one against the Hawks and report back on the difference.
What are the benefits and drawbacks to using the tubular A-arms on a daily driver?
I'm hoping LTs will work as well - getting a set of PaceSetters, so we'll find out soon.................
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
Hmmm... Yes I am very curious as to if the Long Tubes will have clearance now... but I am also wondering about any strength issues it might had with reducing the strength on the right of the car... Obviously a STB would be needed, but even after that how would it be for strength...
I haven't had a chance to speak with him personally due to the fact i'm not back home and been really busy, but once i talk with him, I'll get back to you guys....
It's really hard to find people that are running tubular k-members, yet still use their car as a daily driver......
Bruce told me that he has the tubular k-member in his own car, and it's a daily driver. Although I'm not sure how many potholes they have down there?!
One of the guys at Texas-Speed&Performance told me he's got a friend who did a 3rd gen conversion with a tubular k-member made by Spohn, made some Long Tubes fit, and just re-inforced the k-member with a steel plate.
I'm not counting on anything until I actually get the k-member put into the car, though. We'll see what happens.
Engine: ls1
somehow , i really don't think Hawk's would sell you something that is dangerous for street use and tell you it's ok for that.
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
You do realize all most all performance parts are labeled "Track only" so they don't sued right? I believe the issue of a tubular Kmember and daily driver was discussed in the suspension and chassis board. I believe the outcome is its not a good idea to run it with pot holes as they will eventually bend the A-arms.
I'm not trying to knock anyone's craftmanship here or degrade their credibility, just asking questions and not getting conclusive answers.
When you are fabricating a whole new part, you have the freedom to make a quality design, weld, and pipe, that can be stronger and lighter, vastly superior to the factory compromise.
I can't wait for Spohn's K-member.
Originally posted by Rembrandt
.......I can't wait for Spohn's K-member.
Much the same story as the Spohn Strut Tower brace that a lot of people have been waiting for.
I'm sure the products will be fantastic quality if and when they do arrive. And Steve Spohn will no doubt make sure it IS strong enough for daily driver duty despite the obligatory disclaimer of 'for racing use only'.
Car: blue
Transmission: 6 speed
I keep hearing about the worry of breaking the tube K member. Does anyone really know someone that broke one?? I mean seen the damaged part. Not just some horror story.
I think V6sixtoy (dean) bent his A Arms. No one that I know of has broken the K-member, but the A-Arms are usually the weakest design flaw.
Hey guys,
to help clear this up I run this same Kmember on my 10 second LS third genI drive my car on the street I see both sides of the story,Technically they are for off road use only but I drive mine on the street and have had NO problems. This is what we tell all our customers so it is left totally up to the customer.Keep in mind we also offer motor mount kits and well as modified factory kmemebers that have already been notched if anyone has any questions feel free to call me at the shop.
Thanks,Bruce
www.hawksthirdgenparts.com
Thanks,Bruce
Car: 1992 25th Ann. Z28
Engine: 5.7 TPI - Stock
Transmission: th700 r4
not to be an ***
but who would buy a 3rd gen Fbody, intall the tubular K-member to fit an LS-1 engine and then take it off road?? As mentioned previous.. I assuem the "off-road use only" is just a disclaimer. If it was strong enough for "off-road" use, then it should be more than strong enough for daily driving. Most of us avoid a pothole like the plague just because of the stiff suspension natually assocaiated with a performance vehicle.
just my $0.02
just my $0.02
Re: not to be an ***
just my $0.02
just my $0.02
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
just my $0.02
just my $0.02
no "off road use only" does not mean "offroading" guy.
LOL, that's right. "Offroad" does NOT = a 4X4, it just means for drag strip or race track use.
As to the pot holes, you can avoid 'em all you want, but if you come to some of the northern states, you're gonna run into some sooner or later; Winter, road salt, frost heaves, etc. all mean a bunch of really bad roads all spring and half the summer.
Bohemian
Aug 15, 2017 05:11 PM
dbrochard
Sep 19, 2015 08:13 PM
