l98
Old Jan 10, 2005 | 07:19 PM
steveiguess's Avatar
Car: 1986 Camaro
Engine: zz4 350 w/mods
Transmission: 700-R4 W/Shift kit
l98
what can you do with l98 heads as far as porting, shaving, etc. to flow more and make more power?
Old Jan 10, 2005 | 07:24 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Ditch the TPI .
No seriously, just gasket match them.
Old Jan 10, 2005 | 08:17 PM
Car: 1986 Camaro
Originally posted by pasky
Ditch the TPI .
no tpi, carbed. they are the 58cc heads that come on a zz4 motor.
Old Jan 10, 2005 | 11:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Iguess you need to be more specific.
The areas that typically need work are the bowls under the valve seats, and exhaust ports. If you do the "normal" do-it-yourself porting job, it will help them quite a bit. Shaving won't help unless they need a "clean-up" for flatness sake.
I had a buddy who sent his ZZ3 heads (same thing as ZZ4) off to North Carolina for CNC porting, then to California along with the Bigmouth base, runners, and plenum for extrude honing. That's probably a bit of overkill, but that's what he did.
Old Jan 11, 2005 | 10:22 AM
Car: 1986 Camaro
what would be the advantages of doing what he did, as far as power gain. cuz i have heard that theese heads dont flow much
Old Jan 11, 2005 | 10:21 PM
five7kid's Avatar
The advantage is they flow a lot better than they did before. I don't recall hearing flow bench data, however.
The problem is by the time you do that, you'll have spent as much as you would on out-of-the-box aftermarket heads that flow just as well, and have more performance potential in them.
Old Jan 12, 2005 | 05:46 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The aluminum L98 heads are 58cc... the iroc ones are 64cc.
Old Jan 12, 2005 | 07:02 PM
five7kid's Avatar
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
italiano67
Sep 22, 2015 08:42 AM
