2.8 to 3.8L
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
nope, only engines that will drop right in + tuning are the 2.8-3.1-3.4, reason is is they are all 60* engines, just like the SBC, where the 305-350-400 are all the same on the outside, inside is bored/stroked differently to make the extra cubes.
It is possible to drop in a 3.8, but its alot of custom work, with this kind of work it becomes cheaper to drop in a v-8, and much more rewarding. Anything is possible, what are you planning on doing with the car?
If you are just looking for more power out of a new engine, then i recomend a 3.4, do some headwork and a better cam, and you could see 180rwhp, compared to the 90-120rwhp out of the 2.8.
Want more info on the 2.8-3.4 swap? Check out the Swap Boogie on the tech section at the home page.
Transmission: 4L80E/4L80E
He didn't say the SBC was 60 degree. He was speaking of the v6's not being the same externally, as SBC's are.
As to putting a GN engine in a 3rd gen, that's discussed in the home page FAQs https://www.thirdgen.org/newdesign/faq/thirdgen.shtml , about a forth of the way down the page.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Agreed, but you stopped too soon.
Repunctuated, with additional words added in italics for clarification, it would be: "The only engines that will drop right in + tuning are the 2.8-3.1-3.4, reason is is they are all 60* engines. Just like the SBC, where the 305-350-400 are all the same on the outside, the inside of the larger 60 degree engines are bored/stroked differently to make the extra cubes."
* Sorry this turned into English class, Matt
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
