5.3L from silverado quandry
Old Feb 15, 2005 | 08:46 AM
Meyaht's Avatar
Would a 5.3L from a 2000 silverado mount up to 350 SBC mounts. I can pick it up in running order and only for $850 from a scarp yard here in town, and if it would bolt up to my engine mounts and th-350 it'd be cheaper then a rebuild, plus it only has 36k miles on it. Thanks for the help.
Old Feb 15, 2005 | 09:08 AM
kevosiroc's Avatar
I believe that you will need LS1 adapters for the 5.3L b/c the 5.3 and LS1 share the same block geometry. That would be a cool swap.
Old Feb 15, 2005 | 10:29 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Kevosiroc is correct
its the same as an LS1 swap.. you need the new motor mounts, tranny mount, gas lines, radiator hoses, throttle cable PCM,
then you need a way to splice that harness to your cars body harness for the lights, ignition, gauges, ect.
basically you're doing an LS1 swap.. i would check the clearance of that intake VS your hood. there was a guy on here who was doing this swap and said the truck intake was too tall..
if i were you.. i would get that motor, swap the cam to an LS1, and change the intake to an LS6.. but thats me.
Old Feb 15, 2005 | 10:43 AM
Parrydise7's Avatar
Do a search. This issue has come up before. GM has an instruction book on swapping that engine into a variety of applications, including templates for motor mounts. The book is short (IIRC, 36 pages) and expensive (again, IIRC, around $40 or $50), but probably worth the money.
The truck intake is tall, but a magazine did a test awhile ago (I don't recall which mag) and for making power, that truck intake can't be beat.
Old Feb 15, 2005 | 01:10 PM
Meyaht's Avatar
th350
i've been searching and cant find anything substantial relating to the LS1 going into a th350, anybody here know anything about that? If i could pull that off I'd save alot of jack.
Old Feb 15, 2005 | 02:55 PM
Nikon02's Avatar
Car: 86 iroc
Engine: crappy 350 crate i am building up
it is identical to an ls1 swap the block is the same as motor mounts and such. as far as the intake goes the truck intake is to tall for a regular 3rd gen hood. it would work with a cowel hood, but to make things easier just get and ls1 or ls6 intake on ebay, they are pretty cheap there usually.
if you get guttsy then change the crank (possible the connecting rods) to an ls1 crank and the computer to 4th gen computer and you have a non aluminum ls1 everything else internally is identical from ingectors to bore. (i know the newer trucks even have a simillar cam ut i do not know about the 2000 trucks) The only diffrence between the 4.8, 5.3, and the new 5.7 is the stroke the bore is the same.
Old Feb 15, 2005 | 03:12 PM
Parrydise7's Avatar
If you searched for th350, you probably wouldn't come up with much if anything.
Check out the sticky at the top of the engine swap board about LS1 swaps (the engines are related). It probably has most, if not all, the information you need.
Old Feb 15, 2005 | 09:38 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Wrong recheck your facts. The 4.8 and the 5.3 have the same 3.780" bore but different strokes, 3.27 and 3.622 respectively. The 5.7L LS1 has a 3.90" bore and 3.622" stroke while the 6.0L has a 4.00" bore and 3.622" stroke.
Old Feb 16, 2005 | 07:54 AM
Meyaht's Avatar
TH350 hit some luck
i found through the ls1 sticky that GM makes a flexplate, bolts, and spacers specifically made so you can bolt the LS1 to a th350
also, vegatabul said in a PM that the bolt pattern was the same except tat the 2 o'clock hole isnt tapped. does that mean that i dont need a bolt therre or that i have to tap it and then bolt there also.
Old Feb 17, 2005 | 12:12 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Where is this GM book available? I think it would make interesting reading.
Old Feb 17, 2005 | 02:46 PM
Meyaht's Avatar
also found out that mount plates that bolt to the block would enable me to use the standard sbc mounts, common knowledge to some but cool as hell to me.
also found a 1 ton van form 2002 for $1600. it has a 6.0, 4l60e, and 12 bolt rear end, btu not dualie, i guess thats rare. Ill let you guys know if i land it. if i get a parts car ill use its gauges, ignition, relay box, anything i can take form it. sounds like a good buy as long as the engine's strong, and i could sell the 4l60e and rear for a good chunk i think. lets hope its not crap
Old Feb 17, 2005 | 03:00 PM
Clemson327's Avatar
Car: 1985 Z28
Engine: 383
Axle/Gears: 10 bolt/3.73
Re: TH350 hit some luck
If you try to tap the hole you will break through the cylinder wall. It will hold fine without that bolt there. Four Wheeler did something similar with a 6.0 in an old suburban and they had no troubles whatsoever with it.
Old Feb 18, 2005 | 02:38 PM
Parrydise7's Avatar
I copied this info from the LS1 swap sticky.
There are a couple of publications that you may want to check out. GM has a booklet entitled, "LS1 Engine Kit Installation Guide." Yes, GM does sell an LS1 kit (p/n 25534322).The p/n on my booklet is 88959384. At 36 pages, with a list price of $50.00 I have a hard time recommending it, but it is helpful.
IIRC the booklet has a template for engine mounts (if you need them). Expensive, but loaded with great info.
xkingcodex
Feb 12, 2020 07:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
customblackbird
Oct 1, 2015 04:30 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
fbirdroller
Sep 2, 2015 10:27 PM
