v-6 to 8, can I use the 6 cradle mounts?
Old Mar 15, 2005 | 11:50 PM
Nitrovamp's Avatar
Car: 84' crossfire vette tuned by mmt racing, 73' custom show opel gt, various others as well as my 89' fire chicken
Engine: alot of them
Transmission: alot more
well, I'm just a set of mounts away from having my v-8 swap done, or maybe just a move of them. I have the v-8 horse shoe type mounts already, but can I use the crossmember lower mounts from the v-6? I know there are alot of holes on the cradle, and the mount has to be quite a bit more forward than the v-6 mounts are located at on it. So can I just move the v-6 mounts up, or do I have to buy a different type of mount? -Colt
Old Mar 16, 2005 | 06:51 AM
Xceleratemaro's Avatar
they need to be moved over...you can reuse them..buy why if your going to go through the trouble of taking them out replace them with new ones while your at it..
ps....SEARCH..
Old Mar 16, 2005 | 07:18 PM
Egg83's Avatar
Car: 85 Firebird
Engine: 355 Vortec TPI
Transmission: 700r4 with Pro-Built goodies
Axle/Gears: LS1 3.42 Posi Disc
Definately replace them while you are already in there, i went through this last summer, lol. They are not expensive at all. And yes it is possible to reuse the v6 lower mounts, but they have to be moved toward the front end of the car one set of holes, also be gentile when re-routing the brake lines. I live in Pa where corrosion is a major factor and if you lines look anything like mine did... Good luck removing the mounts
Old Mar 16, 2005 | 11:30 PM
Nitrovamp's Avatar
ok, I've got the new ones for the 8, $9.99 a piece, but no-one told me you have to drop the lower A arms ta' do em. sheesh.
-Colt
Old Mar 17, 2005 | 01:31 AM
Nitrovamp's Avatar
ok, can anyone send me a picture to my email ( pimp_ace2@yahoo.com) or post one of a cradle with the mounts in the v-8 location? I want to be sure I get the right holes, I was gonna put the new larger v-8 mounts on the front-most holes, so as that the bottom front hole on the mount hangs over the crossmember just a lil like on my buddie's elcamino. -Colt
Old Mar 17, 2005 | 08:12 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
You dont need to remove the a arm to replace them..I didnt. Just go through the springs and into the tube with some swivels and extensions....it can be done with some time and patience....
Old Mar 17, 2005 | 10:15 AM
german-motorsport's Avatar
Dont skip work here my friend!
Do it Right!
Drop the A-arms and trash the old soft wobble V6 springs and get new V8 GM ones(???) or better aftermarket springs......
Old Mar 17, 2005 | 12:12 PM
Nitrovamp's Avatar
thank you very much for your guy's help, I'll see what I can do. and thank you for the picture, I was correct about the location.
-Colt
Old Mar 19, 2005 | 04:43 PM
Nitrovamp's Avatar
motor mounts done, I had to drop the suspension, but everythings back together and the engine is in. -Colt
92projectcamaro
Sep 12, 2015 12:33 AM
ynk1121
Sep 12, 2015 12:27 AM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
