Head Gasket Opinions
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
My 406 blew the left head gasket last weekend at the strip,(lean condition caused overheating,shoulda backed out but didn't!)I've got it torn down,everything but gaskets made it unharmed.
What's everyones thoughts on head gaskets?I was running a stock type Fel-Pro,and considering that I know the cause,figured on going back with the same.I am running alum. heads,no steam holes,(normally there's no overheating problem due to way overkill alum. radiator),11:1 compression,nothing all that exotic.I know that copper is considered"the ultimate",but I'm not going to tear it apart to o ring it.What's everones preferred gasket manufacturer,and what part #?What about painting them?I usually don't on the composites,but what's everyone else do?
Just wanted some thoughts/opinions/experiances on the matter
Transmission: 4L80E/4L80E
Drill the steam holes. The temperature of the water going into the engine isn't the issue, hot spots within the block is.
This isn't a steam hole issue,I've ran aluminum heads for years without them,I'm asking for gasket opinions.Is there a brand/style/or application method I'm missing out there somewhere?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Fel-Pro 1003 if you don't mind putting the steam-holes in yourself, or Fel-Pro 1014 with steam-holes already in.
Engine: 383 Carb
Transmission: 4L60
Both are composite gaskets for aluminum heads with a steel core and pre-flattened stainless steel wire rings.
1003 is 4.166" bore, .041" thick
1014 is 4.200" bore, .039" thick
Thanx man,just 1 more question.Is this something parts stores carry,os is it a Jegs/Summit item?I'd like to jam this thing back togethor in the morning and GO RACIN!
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
Call the parts store in the morning and ask them if they have them in stock. Most should be able to tell you if any of thier local stores have them, too.
You've already got the part number
Engine: 383 Carb
Transmission: 4L60
The 1003 should be on the shelf everywhere, the 1014 is a little less common. Both will be in stock at Summit and Jegs.
ambainb
Apr 25, 2016 09:21 PM
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
