My hood won't close!
Old Aug 24, 2005 | 10:25 AM
ammoblows's Avatar
Car: 1982 Z28 Indy Pace Car
Engine: 350 HO 4bbl
Transmission: TH350
I took out the CFI 305 for a 4bbl 350, my hood won't close with the air cleaner on it! Is there something I can do other than cut a hole in my hood? Thanks
Old Aug 24, 2005 | 10:28 AM
ND4SPD86's Avatar
Car: 87 Buick Regal T
Axle/Gears: 2.56 blah
get a drop base air cleaner or get a 2 inch cowl hood
Old Aug 24, 2005 | 10:53 AM
ammoblows's Avatar
Engine: 350 HO 4bbl
Transmission: TH350
don't want to go the hood route if possible. thanks
Old Aug 24, 2005 | 11:17 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I recently swapped in a 350 HO Deluxe which was equipped with a drop base and a 14 x 3 filter element. The hood would close until I reduced the filter to a 14 x 2 1/2. Check the second pic in the followin link:
https://www.thirdgen.org/techbb2/sho...hreadid=314726
By the way, if your cruise control (if so equipped) doen't work, check this thread:
https://www.thirdgen.org/techbb2/sho...hreadid=310552
JamesC
Old Aug 24, 2005 | 05:24 PM
ammoblows's Avatar
Engine: 350 HO 4bbl
Transmission: TH350
how do you hook up the tv cable to the carb?????
Old Aug 24, 2005 | 05:46 PM
JamesC's Avatar
I have a T-5, no TV cable. You might consider a search.
JamesC
Old Aug 24, 2005 | 07:00 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Get a drop-base air cleaner (almost any parts store with chrome stuff will have this) and/or a shorter air filter.
Old Aug 24, 2005 | 07:04 PM
ammoblows's Avatar
Engine: 350 HO 4bbl
Transmission: TH350
got it...thanks.
Old Aug 26, 2005 | 11:46 AM
kboehringer's Avatar
Car: 1982 - Z28
Engine: 350 / CCC Q-Jet
Transmission: THM-700R4
Axle/Gears: 10 Bolt - 3.73
Re: My hood won't close!
The original Cease-Fire operational vent system is hitting? Ours did also....this is what we did......
Removed the rubber seal from the hood.
Cut off the drains and seal with silicone
Add a drain to the rear of the hood's unit.
Remove the stock cover from an LG4 air cleaner and invert the center section by cutting it out and brazing it back in upside down.
Hood closes fine!
Still trying to figure our how to make the scoop "APPEAR" to work.
An LG4 Air Cleaner (with the ductwork) will provide cool air and a stock look.
We're still looking for a Dual Snorkel at the local J.Yards.
DON'T hack the original Fiberglass hood!!! Some guys will pay a small FORTUNE for one in good condition!!!! If you must hack a hood buy one at the J.Yard and store or sell the Fiberglass unit.
Sincerely,
Kurt
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
diana227vegas
Jul 8, 2016 12:27 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
bryan623
Aug 10, 2015 11:33 AM
