header problem on bbc swap
Old Dec 30, 2005 | 04:44 PM
Duke901's Avatar
Car: 89 Formula
I just put the motor in the car and was attempting to put the headers on. But i couldn't get them to go in. Do i have to raise the motor off the mounts alittle to get them in or are they just a pain to put in.
Thank You
Mike
Old Dec 30, 2005 | 06:32 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
always do the tightess side first. Best solution is to lift the engine off both mounts at once and angle them in. I usually have them in before I sit the engine down in the mounts. I believe the driver side needs to go in first..the passenger side w/ the slip pipe goes in fairly easily after there is clearence in the firewall and frame area.....they are not a bolt on without a hammer good luck
Old Dec 30, 2005 | 08:14 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I'm assuming you have the Hooker SuperComp headers. I found the best way is to put those headers in place and tie them up out of the way then put the engine in.
Old Dec 31, 2005 | 12:10 AM
SScott's Avatar
Car: 91 Mustang
Engine: 306
Axle/Gears: 8.8 4.10's
This is from the Hooker instructions if you don't already have them:
LEFT SIDE
1. Remove the spark plugs, exhaust manifold, and oil filter.
2. Starting from below, work the header up and through the chassis into position.
3. With a friend holding the header in place, mark the pinch-weld seam area (weld bead) on the frame, just behind the left lower control arm. See Figure 1.
4. Remove the header and cut the pinch-seam for adequate header clearance.
5. Insert the header back into position. Install the gasket and all bolts (tightening them evenly).
6. Reinstall the oil filter and spark plugs.
RIGHT SIDE
1. Remove the spark plugs, exhaust manifold, dipstick tube, starter, and (if automatic transmission) transmission dust cover.
2. Starting from below, work the main section of the headers up and through the chassis into position and have a friend hold the header in place.
3. Insert the gasket and start all header bolts (most restricted first).
4. Install the dipstick tube and tighten all bolts evenly.
5. Install the starter, spark plugs, and transmission dust cover.
Old Dec 31, 2005 | 02:51 AM
Duke901's Avatar
Car: 89 Formula
yup they are the hooker comps, i guess i will lift the motor back up and then try to put them in.
Thanks everyone
Old Jan 3, 2006 | 06:35 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
The instructions for them leave a little to be desired.
Old Jan 4, 2006 | 09:21 PM
nxfirebird's Avatar
Car: 89 firebird 9.00 @ 150
Engine: 476 bbc
Transmission: T-400
i wish i still had the part ##'s to the motor mounts, but there are 2 sets of solid motors for chevys. you want the taller of the two, i also used the moroso frame pads.
the headers are a pain 'til you get them in once, and yea there's some cutting and beating on the so called "frame rail" to make them fit.
Old Jan 4, 2006 | 09:52 PM
Duke901's Avatar
Car: 89 Formula
ya im using the stock frame and stock small block, block mounts
1984HO
Mar 19, 2021 11:59 AM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
nuggie
Aug 25, 2015 01:27 PM
InfinityShade
Aug 22, 2015 08:00 PM
sreZ28
Aug 14, 2015 07:48 PM
