motor and tranny
Old Mar 19, 2006 | 02:26 PM
blackroc68's Avatar
motor and tranny
Im installing a stealthramed 383 in my 88ta.Can the motor be installed with the tranny bolted to it?700r4.the stealthram is not on the motor
Old Mar 19, 2006 | 02:44 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Yes, but I wouldn't attempt it without a tilt style lifting plate.
Old Mar 19, 2006 | 04:20 PM
blackroc68's Avatar
it has vortec heads!!!!! I was going to go short on the front part of the chain.and havethe motor and tranny tilt back. Hood is off the car!!
Old Mar 19, 2006 | 05:21 PM
Engine: 383 SBC
You might beable to muscle it in there with someone else helping. The tilt style I was talking about have a lever on them and you can adjust angle load by cranking them. Remember to cover the tailshaft or you might end up packing dirt or gravel in it.
Old Mar 19, 2006 | 07:43 PM
blackroc68's Avatar
I am pretty sure i can get it in without any trouble!!! lift motor with tranny then push car under it. The last time i did this was without the tranny but alone.
Old Mar 19, 2006 | 08:00 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
it will be fine, once you get the tranny basically where it needs to be under the car, jack it up with a jack on the tailshaft to level out the motor/trans into the chassis so you can put in the motor mount bolts.
Old Mar 22, 2006 | 12:21 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
http://home.rochester.rr.com/jwfireb...0%233%2003.jpg
first i put the front on blocks, then i take off the bumper and use a cherrypicker, i belive u can rent one if you dont have one. once its mostly in u have to floor jack the trans up in. i think thats easier than removing the trans by itself, i cant get my arms in to unbolt the bellhousing bolts.
Old Mar 22, 2006 | 02:52 PM
Engine: 383 SBC
If you do rent one, try to get a non-collapseable one. There a little more of a pain to move around, but usually have a longer reach on the boon. On mine I didn't even have to extend the boon past 1/2 length and I left the bumper on.
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
drathaar907
Aug 6, 2015 04:20 PM
