ls1 and tbi
Old Mar 21, 2006 | 10:54 AM
jase's Avatar
ls1 and tbi
I was wondering about the hot rod issue and thought about what it would take to make the tbi work.This is a serious idea and I would like some postive feedback.
Old Mar 21, 2006 | 11:44 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The only way is if somebody had come up with a system to put TBI on an LS1 so the LS1 computer would only fire 2 injectors. The TBI would be less efficent than the Port fuel injection and have RPM limits, thus the main reason GM went with the Port injection on the 99+ trucks with the LS based motors.
Old Mar 21, 2006 | 11:57 AM
ljnowell's Avatar
The real question is, why would you want to leave MPFI, to go to TBI? Its a step down.
Old Mar 21, 2006 | 02:56 PM
Biochem's Avatar
Car: 2002 SOM z28
Step? That's the friggin Grand Canyon!
Old Mar 21, 2006 | 05:47 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I suppose I should refrain from giving feedback as it won't be positive. :shrug:
Old Mar 21, 2006 | 05:58 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
I would suggest contacting Black Echo at http://www.goingfaster.com/spo/spo_t...y_central.html
If theres anyone who knows about anything about TBI it's this tool, I mean guy.
Old Mar 21, 2006 | 07:12 PM
jase's Avatar
well I have tbi for starters.And how would it be a step down,when there are other tbi systems besides gm.
Old Mar 21, 2006 | 08:12 PM
Well at one time, F*rd flathead V8s were the fastest thing on the road too; and people built them up because "they had them for starters". But then all of a sudden, everybody that had one just couldn't figure out how to make it run against that newfangled Chevy motor with overhead valves they came out with in '55. They eventually got a clue. Well, most of them, anyway.
Old Mar 21, 2006 | 08:27 PM
jase's Avatar
well the Holley pro injection isn't a bad system.I was just thinking of that on a LS1.
Old Mar 21, 2006 | 09:46 PM
ljnowell's Avatar
If you are going that route than you would want to buy the LS1 carb manifold, and run the Holley TB on it. Im still nto sure why exactly you woudl want to do this. Any kind of TBI setup is lacking when compared to a MP setup.
Old Mar 21, 2006 | 10:28 PM
jase's Avatar
I happen to like tbi and for alot of reasons.I am familar with it and it is pretty simple to work on.tpi or multi port probbaly is for some one who is familar with it.Just like a 350 vs 351.Want ever floats your boat.May not cost too much anyways.It is all part of hot rodding.
Old Mar 27, 2006 | 08:56 AM
Robert91RS's Avatar
Car: 1991 Camaro RS
Engine: 350 TBI .60 over w/ forged pistons,
Transmission: 700-R4 custom built
I know where you are coming from, but as a fellow fan of tbi I should admit to you that you would probably spend countless hours tuning a chip to run the 454 injectors that you would undoubtedly be forced to used in order to aquire the necissary ammount of fuel. But if you can afford the time and money I say go for it! I'd like to see it anyway.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
dbrochard
Sep 19, 2015 08:13 PM
timonator
Sep 17, 2015 06:57 PM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
