305 to 350 help asap!!!
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
will the 305 harmonic balancer work on a 350? i know the flexplate is the same but the balancer has a diffrent part number. need to find out quick the engine is ready to go back into the car.
Engine: 383 LT1
what i really need to know is do the 305 and the 350 have the same imbalance? i know the flexplates are the same so i figured the balancer was too seeing as they work together to balance the engine.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The dampeners are neutrally balanced on both the 305 and 350. You could interchange them without affecting the balance of the engine.
Engine: 383 LT1
Transmission: 4L80E/4L80E
You've got some facts wrong.
First, it's not a harmonic balancer, it's a harmonic damper.
Second, it doesn't work with the flexplate to balance the engine, dampers are neutrally balanced (except for 3.75" stroke SBC set-ups - generally speaking).
Now, damper theory varies a little, but in general, 305 and 350 dampers are designed slightly differently. Plus, dampers aren't a forever part. Best bet would be to go get yourself a new one intended for a 350. You may need to get a new timing tab as well, depending upon the location of the tab on your front cover.
Engine: 383 LT1
what damper can i get that will work on a 350 that is using all the stock 305 tbi brackets and the serpentine setup?
Car: 1992 rs camaro
I'm kind of having the same problem too. I put an L05 from an '87 van into my LO3 1992 camaro. I didn't change the harmonic balancer or crank pulley before I swapped engines. The belt starts to come off if I run it more than about 30 seconds because the pulley from the 350 is 1/2-3/4" shorter than the one from the 305.
I swapped transmissions too. I'm also using the starter and flexplate from the 350 because they're bigger than the ones from my 305 and I wasn't sure if they'd work or not.
So can I use the balancer off my 305 on the 350 and still use the 350 flexplate, or do I have get the L98 balancer? Would an L98 balancer work with an LO5 flexplate? I tried measuring the width of both the pulley and the damper, and it looks like the pulley is the only thing that's a different width.
Flexplates are identical between 305s and 350s, as long as they have the same type of rear main seal (and the same number of teeth - 3rd gen V8s all have 153 or 12-3/4" diameter). '86-up have one-piece rear main seal, '85-back have two-piece rear main seal.
L98 application would be '87-'92 f-body, VIN code 8.
Engine: 383 LT1
ok so i got the new balancer on it is a bit shorter so i just didnt bottem it out i lined up the pulleys and used red loctite so the crank bolt wont back out. on the motor mounts we got one of them to seat but the other wont i put in new polly mounts can u put those in backwards cause it looks like the one that wont seat is catching on the metal strip that sticks out of the end of the polly mount.
