What starter for my engine
Old Oct 6, 2006 | 09:45 PM
88_Bandit's Avatar
Car: 88 Trans am
Engine: high comp vette engine.
Axle/Gears: 308
Well I have a 1969 engine in my car and i tried to change the flywheels so it would fit my new starter that i bought for the old engine and the engine is older so it would not fit, so now i tried using the new starter i bought for the old engine with the new engine (69 350)and i had to shim it quite a bit due to the 14 inch flywheel, btw this is an auto, and it works sometimes but most of the time i have to get back under the car and loosen up the starter bolts and the gear on the starter goes back in. then its good for like 6starts then it grinds again and now no matter what i do it just grinds. so what starter should i put on this car for it to work. my flywheel is fine nothing wrong with it, but the gear on the starter is shot help me fix this car.
Old Oct 6, 2006 | 10:03 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
You need a starter for a 14" flywheel.
Old Oct 6, 2006 | 10:47 PM
88_Bandit's Avatar
Car: 88 Trans am
Axle/Gears: 308
yea thats right but what car came stock with a 14inch flywheel that is the question i was asking
Old Oct 6, 2006 | 10:53 PM
Lo-tec's Avatar
The car your 69 motor came out of.......or get an early 12 3/4" flywheel for ...say an 84 camaro...and put it on your motor and re-use your starter.............
Old Oct 7, 2006 | 03:39 AM
88_Bandit's Avatar
Car: 88 Trans am
Axle/Gears: 308
did u know the engines changed since 69 and the crank comes out on the back and thats where the flywheel bolts too. so u cant just go and buy a 12 3/4
Old Oct 7, 2006 | 07:08 AM
Lo-tec's Avatar
and where, pray tell, did the crank come out before 69 and what did the flywheel bolt to then?
Seriously, you have a 2-piece rear main seal crank, and yes, an 84 camaro came with a 12 3/4" flywheel that would fit your application. The easiset thing to do is pull your starter, go down to pep boys, and have them look up a starter for a mid 70's chevrolet whatever with a small block. One of them should be for the larger flywheel...you can tell by the bolt pattern on the starter. One has offset holes and one has holes straight across. Whichever one you have, get the opposite.
Old Oct 7, 2006 | 02:17 PM
88_Bandit's Avatar
Car: 88 Trans am
Axle/Gears: 308
welll im not sure that i have a 2 peice rear main seal but i know the crank shaft stick out quite a bit and thats where the flywheel bolts to so i really dont know what i should buy
Old Oct 7, 2006 | 02:21 PM
Lo-tec's Avatar
Buy the correct starter after re-reading this post.
Old Oct 7, 2006 | 02:27 PM
88_Bandit's Avatar
Car: 88 Trans am
Axle/Gears: 308
i dont have the orginal starter it broke, and the flywheel needs to be 13inches to fit my starter.
Old Oct 7, 2006 | 04:21 PM
88_Bandit's Avatar
Car: 88 Trans am
Axle/Gears: 308
i figured out my problem i need a flywheel that will match the stock starter for the stock T/A engine. so basically i need a 153tooth flywheel that will fit the 2 peice rear main seal.
Old Oct 7, 2006 | 08:53 PM
Lo-tec's Avatar
All you need is the correct starter. There are 2 types, and I'm posting pictures of both. Whichever one you have, you need to buy the other (the one for a 168 tooth flywheel). It should be the one with the staggered bolt holes. I hope the pictures help.
Attached Thumbnails What starter for my engine-12.jpg   What starter for my engine-14.jpg
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
milk
Aug 10, 2015 06:26 PM
