Summer = Possible Engine Swap.. I have questions.
Old Apr 16, 2007 | 03:40 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
I heard that I can got to a salvage yard and find a 350 for a few hundred dollars. Is this true, is it worth it, should I be looking at 350s from TPI camaros or are there other cars that I can get one from? What should I be looking for?
I need all the info I can get.
-Peace
Old Apr 16, 2007 | 03:49 PM
xgtharo86x's Avatar
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
Axle/Gears: 2.73 Posi
Re: Summer = Possible Engine Swap.. I have questions.
i have the same question and how do you tell if its a 2 or 4 bolt main..i know that they cost about 200 bucks if they knew they ran but dont know what to look in or for
Old Apr 16, 2007 | 04:57 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
You guys need to look for one of the newer vortec 350 engines if you're wrecking yard searching.
A 350 TPI is a great find for your swaps (either car) but they are starting to get rare. A 350 from a newer (88 or newer) pickup with TBI fuel injection is a good one to start with as well. I think the best are the 95 and newer vortec 350s that came in pickup trucks and vans. I'm not sure what the last year is that they came in trucks but my work van is 2001 and it has one in it. It is a 350, has vortec heads, factory roller cam and can be had cheap.
Just my opinion guys...
Old Apr 16, 2007 | 05:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it matters, you pull the pan off and look, but it doesn't matter.
Old Apr 16, 2007 | 05:34 PM
xgtharo86x's Avatar
Car: 86' Trans am
i heard that 4 bolt mains are stronger is that true..and how do you tell if its a 350 if its missing the info under the hood
Old Apr 16, 2007 | 05:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
4 bolt mains aren't stronger in any way that will matter for a street motor.
Measure the bore or check the casting numbers to find out if its a 350.
Old Apr 16, 2007 | 05:46 PM
xgtharo86x's Avatar
Car: 86' Trans am
is there a certein casting number to look for I know theres one on the deck on the pass side and one on the back of the block
Old Apr 16, 2007 | 05:55 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
You need the one on the back of the block, which may or may not tell you what it is. Sometimes certain castings came in 2 or 4 bolts. Again, as stated, if you needed a 4 bolt main, you wouldn't be asking how to find out if it's a 4 bolt.
Old Apr 16, 2007 | 06:01 PM
xgtharo86x's Avatar
Car: 86' Trans am
alright,thanks i dont really care if its a 2 or 4 bolt i just want to get rid of this damn 305....whats the easiest way to find out if its a 350 on the spot cuz these 350 go like hot cakes
Old Apr 16, 2007 | 06:05 PM
Engine: 400
Bring a huge list of casting numbers. *shrug* Or write down the casting number, go home and look it up and come back. Also, is your engine a 85? If so, you'll need a 85 or earlier 350. You need a 2 piece rear main seal engine OR you can buy a 1 piece rear main seal flexplate (if you buy an engine with a 1 piece seal).
Old Apr 16, 2007 | 06:27 PM
xgtharo86x's Avatar
Car: 86' Trans am
ya the code on the deck said it was a 85 305 code is (V0816cdf/1fr100432)..I have another question if i get an 86 and newer engine can i just take the 1 piece rear main seal flexplate that came with it...and can i use my 305 wire harness or do i have to take the 350 one...i dont have an computer or emissions if that helps thanks for your time
Old Apr 16, 2007 | 06:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
305 and 350 will use the same flexplate.
Old Apr 16, 2007 | 06:38 PM
CG_1985_Z28's Avatar
Car: 1985 Z28 camaro
Engine: lq4
Transmission: th350
best swap is for the tpi 350 out of the newer third gens... they are torque monsters! great moter. if u wana stay with a carb u can get a 4bolt main truck block for pretty cheep.... good luck!
Old Apr 16, 2007 | 06:46 PM
xgtharo86x's Avatar
Car: 86' Trans am
can i use my 305 wire harness because i have no computer or emissions or do i have to use the 350 wire harness
Old Apr 16, 2007 | 08:37 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Depends on the fuel injection style. In all likelyhood, if you use a fuel injected 350, the fuel map will be different from your 305 and to get the engine to run it's best you would need to either use a different chip or different computer.
If you use a carb'ed model, you can use the stock wiring for the most part. If you are retrofitting a carb into your fuel injected model, you will have to do some modification.
Old Apr 16, 2007 | 08:50 PM
xgtharo86x's Avatar
Car: 86' Trans am
its a non cc qet i removed the computer and all its components so i can use the 305 harness
Old Apr 16, 2007 | 10:55 PM
blackphoenix's Avatar
Engine: VORTEC 350 & LT1
Transmission: T5 & T56
Hello. I see you are in PA if you are located near Allentown I am minutes away. It is a 350 TBI. It has 55,000 miles on it. It IDLES PERFECT and starts EVERYTIME, all the TIME no EXCEPTIONS. VERY STRONG MOTOR. You can hear run if you are interested it is well worth you checking out. You must pull the engine and can have the complete engine. Let me know if you are interested email formula_tpi@hotmail.com or call 610-972-6433.
84z96L31vortec
Aug 20, 2017 12:16 AM
69 Six Pack
Oct 5, 2015 07:51 PM
86White_T/A305
Aug 17, 2015 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
