My engine swap thread. 305-400 sbc swap.
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
Its been almost a year since the car hasnt been running, Im finally starting to see some progress.. Heads have been off.
I have a hoist ready to go. Heads are at machining. I need an engine stand, Oilpump, rocker arms, gaskets, then to do the work on the 400.. but so far
Just un-bolted the starter. Got cleaned up to ask how I unbolt the T/C and now I have to go somewhere, Ill continue with the next 3 days( 5 day week end for me
-Matt
)-Matt
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Re: My engine swap thread. 305-400 sbc swap.
To unbolt the TC, you will need to remove the inspection cover underneath the car. It may be plastic sometimes aluminum.
The TC is held on by 3 short bolts. Fit a socket on it with a rachet, use the end of a jack handle to use as a breaker bar. Break the bolt lose but do not remove it.
Take a very sturdy perferably forged flat tip screw driver into the square slot on the boss for the bolt. Use the screw driver to move the TC until you meet the next bolt. Break the remaining two then remove them.
Good luck.
Good luck.
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
thanks, i got some advise from some one saying to turn the motor over by hand Im not sure if its hyrdolocked yet or not.
whats the best way to chain the motor with out heads on?
Car: GTA
Engine: 383 HSR
There is a thread on the highest point on the bellhousing (you can get to it with the tranny in)
then you can use the water pump holes, just make sure you bottom out all bolts and it will work fine.
If you can figure a way to run the chain through the head bolts to the block that would be best. Or simply bolt the heads back on with a few bolts very tightly and run the chain through the assortment of accessory holes.
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
I cant get the flex plate to rotate, I got one bolt out, I got to one but when I used the wrench the flex plate moved with it. I also broke the bolt for the crank.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you broke the bolt in the balancer? wow, stupid question did you take out the spark plugs?
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
I had no heads on, The bolt broke, the tq bolts are out, the engine is out, and unfortunetly so is the trans
Car: GTA
Engine: 383 HSR
If you want to free the engine just pour brake fluid in the cylinder bores. When you wake up in the morning it will be free.
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
I got the th350 off the 400 yesterday, and on the stand yesterday, today I made a little bit of progress
Car: GTA
Engine: 383 HSR
Did you try pouring brake fluid in the cylinder bores? It will work, I am telling you.
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
the old motor is out and the trans is unbolted, its too late. thanks for the tip though
Car: GTA
Engine: 383 HSR
Too late for what? You got the pistons out of the block already? Does the motor turn by hand?
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
I am slow
:mrgreen: Just got done putting the heads on so I decided Id just put the intake on and see what she will look like
400+ sbc.
vortec heads, performer rpm intake. 750 cfm carb. 234/244 @ .050" .488"/.510", 114 LSA + nitrous and 3000 stall
400+ sbc.
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
nice job I like the look!
theshackle
Mar 5, 2017 06:37 PM
