1990 350 TBI to 1991 305 TBI Swap?
Old May 30, 2007 | 09:01 PM
Tims91RS's Avatar
Getting the motor from a Caprice which has a mechanical fan. If I have to use the pcm and chip from the Caprice how will my electric fan (Camaro)know when to turn on?
Old May 30, 2007 | 09:52 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Re: 1990 350 TBI to 1991 305 TBI Swap?
what a waste!!!!!!!! just get it TPI
Old May 30, 2007 | 10:10 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
how come you're swapping from a 350 to a 305?
Old May 30, 2007 | 10:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm going to assume that since the username is "Tims91RS" that the "from" is the Caprice and the "to" is the Camaro.
That being said, you might get more help from the TBI forum. Those guys are more familiar with the workings of the 3rd gen TBI and the various forms that are swapped into them.
Old May 31, 2007 | 01:26 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The single fan system in the f-body is not controlled by the ECM. Its controlled by the temp switch in the passenger side head. Install a 160 or 180 degree thermostat and a 185 or 200 degree aftermarket fan temp switch, and you'll be fine.
Old May 31, 2007 | 11:24 AM
five7kid's Avatar
Thanks, Kevin, that's what I was thinking but wasn't sure about the TBI fan set-up (just not all that much exposure to TBI cars).
Old May 31, 2007 | 08:27 PM
Tims91RS's Avatar
Thanks guy's it was a 305 to 350 swap.
Old May 31, 2007 | 09:33 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Not to be confused, The Temp Switch is actually located on the drivers side of the motor on the side of the block, Look for a white and green wire and it will lead you right to it.
Old May 31, 2007 | 11:25 PM
Kevin91Z's Avatar
The fan temp switch is in the passenger head like I said. The gauge temp switch is in the driver's head like you said. The ECM temp switch is in the front of the intake manifold.
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Sanjay
Aug 12, 2015 03:41 PM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
