motor mounts
Old Jul 3, 2007 | 08:48 PM
70gmc's Avatar
Car: 1970 GMC LWB Street strip
Engine: 383 stroker
Transmission: 350TH
Axle/Gears: 12 Bolt 4:11
motor mounts
Hey guys got a 87 iroc and the motor is out im gonna replace the motor mounts. My questions is on the three 5/8 bolts holding them to the cross member is there nuts on the back side. if so how do i get to them? thanks
Old Jul 3, 2007 | 09:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: motor mounts
Yes, there are nuts and washers on the back side inside the K member. A search will turn up all sorts of enlightening information on the joys of accessing them.
Old Jul 3, 2007 | 09:22 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: motor mounts
Personally, I like long "wobble" extensions and u-joints wrapped with electrical tape!!
Let the fun begin!!
Old Jul 3, 2007 | 10:53 PM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
Re: motor mounts
Are they 5/8 or 9/16? The ones I got from a donor car were 9/16. I used a distributor wrench to get at the bolts through the crossmember. Worked good.
Old Jul 4, 2007 | 10:29 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: motor mounts
they are metric, between 5/8 and 9/16 i believe. they are a whole lot of fun to get out. to make things better, there are washers on the nut side as well. they are easier to get at with the a-arms out, but it can be done with everything still installed. i got mine off with a long 3/8 extension, a swivel and a crows foot wrench. its a real PITA, but its possible. you will need a second person to work from the top. you can sit a work light on the a-arms shining into the k-member from the mounting points for the a-arms and that will give you enough light inside of everything to see the nuts. the passenger side is a little harder because everything is shifted a bit, so the nuts are in there a little further.
Old Jul 4, 2007 | 11:43 AM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Re: motor mounts
All in all, probably the easiest thing to do is drop the a-arms down, by taking the springs out and you can reach them from there. I did mine in about hour and a half
Old Jul 9, 2007 | 01:04 PM
Blackhawk355's Avatar
Car: 1989 Firebird
Engine: N2O 355CID
Re: motor mounts
motor mounts are all but too much fun to say the least.
Old Jul 9, 2007 | 01:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The nuts inside the crossmember take a 15mm socket/wrench.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
