305 to 350 engine block swap
Old Aug 16, 2007 | 12:39 PM
Irocon's Avatar
Car: 1986 Chevy Camaro Iroc-Z
Engine: 350 5.7L
I am looking to swap my current 305 block with a 350 one. Would the external engine parts that i currently have be compatible with the 350 block?
Old Aug 16, 2007 | 12:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 to 350 engine block swap
Yes, especially if you're swapping in a block of the same vintage.
Old Aug 16, 2007 | 12:48 PM
Irocon's Avatar
Engine: 350 5.7L
my current block is from 86 would the 87 350 still be compatible?
here's the link
http://www.hiperformer.com/featured_..._350llb_4.html
Old Aug 16, 2007 | 01:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, but you'll need to change the flywheel or flexplate.
Old Aug 16, 2007 | 01:12 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Sorta. I think your intake manifold bolts need to be modified, at least the center two.
Aside from that I think you're good to go, it's still a flat tappet setup, and runs 193 heads... It's far from a high performance 350, but at least you're doing better with cubes.
What induction do you have now?
You know, that sidebar where members put their car info? It's pretty handy, that saves me (and everyone else in future threads) having to ask.
Old Aug 16, 2007 | 01:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The intake doesn't bolt to the block.
Old Aug 16, 2007 | 01:23 PM
Sonix's Avatar
Car: 1982 Trans-Am
Uhhh huh.... So far so good.
This is a long block in the link, with 193 heads. I just assumed he was putting his 1986 Carbed intake and carb on top.
Old Aug 16, 2007 | 01:24 PM
Irocon's Avatar
Engine: 350 5.7L
So would it make more sense to stick with the 86 350 block or a newer one?
Old Aug 16, 2007 | 01:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
With the later block you could run a factory roller cam setup. Other than that I wouldn't care.
Old Aug 16, 2007 | 01:41 PM
Sonix's Avatar
Car: 1982 Trans-Am
Exactly. I'd get that as a shortblock though, there isn't much you can do with 193 heads. Or the lame peanut roller cam they'd give you, for that matter.
Old Aug 16, 2007 | 01:45 PM
Irocon's Avatar
Engine: 350 5.7L
they do offer perfomance options. What heads and roller cam would you suggest that would not break the bank?
Old Aug 16, 2007 | 01:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Performance cams all cost more or less the same, so it doesn't matter what you choose there. Your choices depend somewhat on what you're intending to do with the car.
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
st.evel07
Aug 13, 2015 06:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
