tbi-carb swap-no more reverse lights??? whered they go?
Old Sep 9, 2007 | 03:24 PM
chevycamaro91's Avatar
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
i swapped tbi-carb and no more reverse lights? i tired doign a search but i couldnt find any info really. all ymy other lights work just no reverse lights? any suggestions? oh and i have a 5 speed if that makes a difference thanks
Old Sep 9, 2007 | 04:49 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: tbi-carb swap-no more reverse lights??? whered they go?
The reverse lights are a plug on the passenger side of the trans at the top. Check that first.
Old Sep 9, 2007 | 09:36 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
well they worked before and after the swap they no longer work. so somewhere along the swap a plug got disconnected or something. for some odd reason the reverse lights dont work thru the ecm do they?
Old Sep 10, 2007 | 12:36 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
your electrical circuit shows that it goes from fuse box-backup switch at trans-lights. check for a blown fuse.
Old Sep 11, 2007 | 03:00 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
On some cars the Reverse light wires ( 1 blue and one green ) run through the cars ECM harness. If you swapped harnesses and the engine/harness was from a automatic car - than that's why you lost the reverse lights.
I converted my 84 Berlinetta from auto to stick and removed the entire ECM system. I found a 5-speed Carb ECM harness in the bone yard that was shreded to use in it's place. The ONLY 2 wires that were not cut cut short and that are still connected to that harness are the reverse light wires.
P.S. On (some) manual camaros the 2 reverse light wires run though the ECM harness at one of the 2 ECM plugs that connect to the DASH harness. I don't remember the PIN numbers - but look for a Blue and a Green wire !
Hope that helps in some way !!
Last edited by John in RI; Sep 11, 2007 at 03:01 PM. Reason: clarity ....................
Old Sep 11, 2007 | 03:19 PM
Stevo's Avatar
Car: Pair of 92 Z28s
So this brings up my next question, since i am removing my computer any way to get my reverse lights to work correctly without the ECM? Any ideas?
Old Sep 12, 2007 | 11:43 AM
according to the wire diagram for your 92 (not a berlinetta) you can remove your computer without affecting the backup lights. (see my post above for your specific routing) the berlinetta is the only camaro which had the reverse lights going thru the ECM.
Old Sep 13, 2007 | 08:35 PM
Stevo's Avatar
Interesting, ill just trace them down because i have to pick through both wiring harnesses anyway. Thats good news though.
Old Sep 13, 2007 | 08:50 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
thanks duckman & john. i havnt had a chance to look at the lights but im gonna try to figure it out tomarrow. tahkns for the info im sure itll help
Old Sep 15, 2007 | 07:33 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
question: theres two electrical "ports" on my t5, 1 for vss and the other one im guessign is for the reverse lights. does the connector that goes into the reverse light port have a blue and green wire coming from it?
Old Sep 15, 2007 | 10:57 PM
Stevo's Avatar
yes.
Old Sep 16, 2007 | 06:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's a pic of my 85 IROC (the computer was removed. Note the blue and green wires in the first pic):
https://www.thirdgen.org/forums/engi...-function.html
JamesC
Old Sep 16, 2007 | 12:29 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
alright welll i got them working! turns out the connector wasnt making full contact, thanks everybody
TheJoeY88
Dec 31, 2016 07:30 PM
Jae992
Aug 27, 2015 09:07 AM
Polo Z03
Aug 14, 2015 10:49 AM
Omega
Aug 10, 2015 12:46 PM
hokis
Aug 9, 2015 03:57 PM
