700r4 to LS-1? Will it work?
Old Mar 13, 2008 | 02:59 AM
elite_4automoti's Avatar
Car: '90 Camaro RS
Engine: 3.1 V-6
Transmission: 700R-4
Axle/Gears: Puny ones
I was reading the sticky on swapping in a LS-1 and the the part on transmissions wasnt too clear on the 700r4. will a 700r4 work or not? the article only says a 4l60e is just a 700r4 with electronics. Does that mean it will work or not?
Confused.
Old Mar 13, 2008 | 06:11 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: 700r4 to LS-1? Will it work?
You will have to rig up for the TV cable to the throttle body, but easiest way to go is to get a 4L60E, you'll save yourself alot of headaches doing that.
Old Mar 14, 2008 | 12:33 AM
Car: '90 Camaro RS
Engine: 3.1 V-6
Yeah, a 4l60E would definately be the easier way, however I just spent about $900 on a bulletproof 700R4 that I havent even put in the car yet. I was going to swap in a T.P.I. 383 but got a truly good deal on a LS-2 from a wrecked GTO. I could use the t-56 it came with but I like having at least 1 "lazy-shift" (Automatic). Still, will it bolt up? If my only problem is going to be the T.V. cable then it will be easier than I thought....
Old Mar 14, 2008 | 01:15 AM
metalic5's Avatar
Car: 87 GTA
Engine: 5.3 LSx
Axle/Gears: 3.70 Borg Warner 9 bolt
well i have a 700r4 hooked up to my 5.3 LSx swap, all i did was get the gm flywheel for LS motors which allows them to hook up to older tranny's, then bowtie overdrives sell the tv cable to hook up to an LS motor, the tranny bolts right up to the LS motor all bolts line up except the motor doesnt have one, so you'll end up one bolt less, and the only thing that you'll have to figure out is the speed, and lock-up converter, but theres kits for that, i just havent dont it, i'm broke.
Old Mar 14, 2008 | 06:19 AM
Klortho's Avatar
Car: 1987 GTA
If you can get the T56, you will end up having more fun with that in the car than having an automatic. Also, I don't know if not having the 4L60E connected to the LS2 computer can cause problems. Plus the PCM in the car will be for a 6-speed, not for sure about how the programming works for that either which could be even more problems as well.
The LS2s use a totally different PCM than the LS1 or truck engines use, might be worth digging around on LS2.com and see.
Old Mar 15, 2008 | 02:43 PM
Car: '90 Camaro RS
Engine: 3.1 V-6
Metalic5; I appreciate that. you mean there is a spedometer problem? The lock-up problem is easy to fix.
thank you.
Old Mar 15, 2008 | 02:52 PM
Car: '90 Camaro RS
Engine: 3.1 V-6
Klortho; The ls-2 I'm looking at has the 6-speed hooked to it, but no electronics. I think I'm going to use a FAST xfi for the electronics. I havent made up my mind weather or not to use the 6-speed in my camaro or not. I have an el camino that I am building an LS-7 for and it is almost done. I would really like to put that in my el camino! Do you know if I am going to have to get a camaro oil pan or will the GTO pan work in my camaro with k-member mods?
Thank you!
Old Mar 15, 2008 | 02:58 PM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
Transmission: Built 700R4 w/ 2500 stall
Axle/Gears: 3:73 posi
On some flexplates, you have to get an adapter plater to match the that to the converter. not sure about the details on that tho.
Old Mar 16, 2008 | 02:04 AM
Car: '90 Camaro RS
Engine: 3.1 V-6
Does anybody have the answers to the flexplate adaptor issue? These engines have been around for a while and yet it seems that no one has the answers to them.
Old Mar 16, 2008 | 02:22 AM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
just do a search for it on yahoo, i looked it up a while back when contemplating a ls swap, if i find it again ill tell you
Old Mar 16, 2008 | 11:45 AM
macdadyZ28's Avatar
Car: 87 Formula
Engine: '00 LM7
Transmission: 4L60e
Axle/Gears: 3.23 posi
easiest setup in my opinion is the 6.0L flexplate with GM spacer and spacer bolts. bolt holes directly line up with large bolt pattern th400/350/700-r4 torque converters since 4l80s use the same pattern. a washer between the TC and flexplate and you should be fine on spacing then. you will need something to fix the TV cable though.
Old Mar 16, 2008 | 06:21 PM
84ls1_transam's Avatar
Car: 1984 Pontiac Trans Am
Engine: LS1 Zex Direct injected
Axle/Gears: 4.88 Moser 9"
I would say don't waste your time on a 700. I bought one that was supposedly a great rebuild with a nice shift kit. It lasted one run before it started slipping. I would say T-56 which is what I am running now and love it, or 4l60e.
Old Mar 16, 2008 | 06:39 PM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
no reason an incompetant tranny builder should give a tranny a bad name, there is nothing wrong with a properly built 700
i would agree, a 6 speed would be a blast tho!
Old Mar 19, 2008 | 12:24 AM
Car: '90 Camaro RS
Engine: 3.1 V-6
I appreciate all the help. Still havent made up my mind on the tranny issue. The shop building my 700R4 is sort of a friend of a friend sort of deal. They havent said what the "real-world" price would be if I was just some joe off the street, and I consider it to be rude of me if I were to ask, but I suspect it would be around 2500.oo! I really dont want to abandon what is undoubtably an awesome tranny. I figure if I blow it up, then I can always put the T-56 in.... Still havent figured out the T.V. cable issue,however...
Old Mar 19, 2008 | 12:38 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
If they can build a proper TH700R-4, they can build a proper 4L60E.
Old Mar 19, 2008 | 07:20 AM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
im sure they can but thats not what he has, the point of this is to use what he has.
Old Mar 19, 2008 | 09:25 AM
five7kid's Avatar
The point is to get something to work.
Putting time and money into something that needs to be crutched and band aided doesn't make sense when most any competent transmission shop can build, and very likely has or can easily get, something originally made for the task.
It wouldn't surprise me that there have been more 4L60E's made than TH700's.
camaro11j
Sep 19, 2018 08:49 AM
Reddeath210
Oct 6, 2015 08:20 AM
TreDeClaw
Aug 14, 2015 06:58 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
