TPI EGR?
Old Apr 8, 2008 | 09:54 PM
thesargster4's Avatar
Car: 1986 WS6 TransAm
Engine: THREEFIDDY!
TPI EGR?
I swapped my 86 RS's 6 cyl with a 350 TPI, but the engine was originally a vortec out of a marine application, im using a ECU that was chipped to run a vortec, but was modded for my cam and the TPI.. obviously a custom harness. I have the EGR wire for a 00'+ vortec style EGR, and i just have it blocked off and the smogger is going to shoot me next month when he notices it, is there any egr valve for a vortec engine that will mount to the tpi base plate, or what would be the best model egr to go with and mod, and how should i mod it?
John
Old Apr 8, 2008 | 10:21 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: TPI EGR?
so you have vortec TPI setup on a vortec headed motor thats using a newer style ecm for that vortec motor?
I dont know of a EGR valve that wil work with TPI and later model harnesses.
You can run a thirdgen TPI wiring harness tho and run factory TPI L98/LB9 style EGR valve. what you will need to do is run the SDPC vortec EGR kit. You get the exhaust from the header tube, and run it to the back of the TPI base manifold where it will feed the EGR valve. this is how corvette L98's do it
Old Apr 8, 2008 | 10:23 PM
Engine: THREEFIDDY!
Re: TPI EGR?
I have a vortec block, with 89 style heads and a 89 TPI. an OBD-II ECU/Harness modded for the TPI. Has the EGR wire for the Vortec CSFI setup. Tell me more about this SDPC vortec egr kit?
John.
Old Apr 8, 2008 | 10:33 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: TPI EGR?
IIRC the vortec EGR is all electronic. The 89 TPI has an electric controlled vacuum switch(?) to the valve located under the plenum. some one please jump in if I screwed that up.
Old Apr 8, 2008 | 10:35 PM
Engine: THREEFIDDY!
Re: TPI EGR?
Yes, im quite sure your correct on that one m8. But that isnt necessarily helping the situation, i dont want to be running in open loop with the EGR disconnected.. So i need to find some kind of kit or help to mod a votec egr to sit on my base plate :-O
Old Apr 8, 2008 | 10:47 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: TPI EGR?
ahh obdII setup, thats what i want to do but i dont need EGR. the 89 heads and 89 TPI are fine, i just wonder if you can adapter the 89 EGR wiring plug to the OBDII harness just with a simple cut and splice, but yeah TPI one has a switch thats electronic and vacuum operated
Anyway, the SDPC kit is like this. It runs the L98 corvette style EGR system. Instead of getting exhaust gas from the heads like the camaro/firebird, the corvette gets it from the header and it feeds back into the rear of the manifold.
i cant find a picture at this time tho. sdpc doesnt have the pic either but heres the link to the kit
http://www.sdparts.com/product/SD381...Baseplate.aspx
problem is you STILL would need to convert to TPI harness
Old Apr 9, 2008 | 01:27 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: TPI EGR?
Here's how I did the EGR on my Corvette L98 heads:
https://www.thirdgen.org/forums/post...36-post11.html
Old Mar 17, 2009 | 09:16 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: TPI EGR?
So what do I do if I'm putting a 1989 TPI from a Corvette in my 87 Iroc?
I want to be able to pass smog.
Old Mar 17, 2009 | 09:21 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: TPI EGR?
Sorry posted in the wrong one
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Out-Cast
Aug 17, 2015 10:57 AM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
