BB Swap Pics
Old Jul 8, 2008 | 12:03 PM
booboosean's Avatar
Car: 1989 Camaro RS
Engine: 396 BBC
Transmission: Turbo 400
Axle/Gears: Moser 9 inch/4.56 gears
BB Swap Pics
Hey guys, it's been a while since I've been on the forum.
A lot of people showed interest in my post on the Patriot header swap. I've been driving the car and enjoying it a lot. So, here are a couple pics of the car at the cruise-in I went to last week.
Old Jul 8, 2008 | 03:13 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: BB Swap Pics
very nice and clean install. Looks great!
how is it to work on? spark plugs, oil change, valve cover removal?
any major handling differences with the added weight to the front? What trans are you running?
Old Jul 8, 2008 | 10:07 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Re: BB Swap Pics
Did you use BBC mounts?It seems to sit higher than mine.What ps steering brackets did you use?The last time I just fabricated one(I sucked at it) and use the SBC brackets.Pics would help me a ton thanks
Old Jul 9, 2008 | 07:39 AM
booboosean's Avatar
Car: 1989 Camaro RS
Engine: 396 BBC
Re: BB Swap Pics
Daz,
I believe all your questions can be answered from the original thread:
https://www.thirdgen.org/forums/engi...tml?highlight=
I used the small block mounts with energy suspension urethane biscuits. They make the engine sit up about 1/4 inch higher since they do not crush like rubber. The alternator and ps brackets are Alan Grove units.
3rdgenmaro,
Thanks for the compliment. It is very easy to work on since the A/C and wiper motor are gone. It is an RS....so it never handled very well to begin with. With the relocation of the battery and losing the A/C, I didn't gain much weight on the front. I'm running fats on the back and skinnies on the front, so I'm not that concerned with handling (old school )
I will post some more pics later this week.
Boo.
Old Jul 9, 2008 | 11:16 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Re: BB Swap Pics
you have the partnumber for the Alan Grove brackets?
Old Jul 10, 2008 | 07:36 AM
booboosean's Avatar
Car: 1989 Camaro RS
Engine: 396 BBC
Re: BB Swap Pics
Ok, I've had quite a few PMs on the accessory brackets. I used the Alan Grove mid mount alternator bracket (I thought the mid-mount looked cleaner) and I used the Alan Grove PS bracket for long water pump.
In order to clear the steering box, the PS bracket had to be slightly modified. I drilled an extra upper hole and pivoted the bracked up (see 1st picture). This gave plenty of clearance for the pump pulley (see 2nd pic).
The pulleys are all Billet Specialties (big block long water pump).
Old Jul 10, 2008 | 03:48 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Re: BB Swap Pics
Attachment 160147
Attachment 160148
Exactly what I was looking for!!!..Thanks a ton!
Old Jul 10, 2008 | 08:29 PM
booboosean's Avatar
Car: 1989 Camaro RS
Engine: 396 BBC
Re: BB Swap Pics
Glad to help. The rear of the bracket is just like the front. When I drilled the new hole, I clamped the two pieces together in a vice and drilled them stacked together to ensure alignment front to back.
Old Aug 1, 2008 | 10:25 PM
MouseToRat's Avatar
Re: BB Swap Pics
Boo,
I like the old school look of the wheel/tire combo. What are the specs?
Thanks.
Old Aug 3, 2008 | 12:59 PM
booboosean's Avatar
Car: 1989 Camaro RS
Engine: 396 BBC
Re: BB Swap Pics
Originally Posted by MouseToRat
Boo,
Thanks.
I'm using the Summit Racing "Star" wheels (they are Weld knock-offs). I like the fact they use conical seat lug nuts, so I was able to use my factory lug nuts. I used the 15x8 in the rear (it hs a 4.5" back space) and the 15x4 in the front. For tires, I used Mickey Thompson ET Street Radials 275/60R15 (rear) and a Kumho 205/75R15 in the front. Most people prefer a 205/70R15 in the front; however, I wanted a little taller tire. A 165/80R15 is a common skinny too (Old Volkswagen Beetle tire).
There are no clearance issues with this combo. No mods to the wheel wells were made and they don't stick out.
Old Aug 3, 2008 | 09:19 PM
Bowtiebruiser's Avatar
Car: 1982 Camaro Z-28
Engine: 350 4bbl
Transmission: Borg Warner Super T-10
Axle/Gears: Richmond 10 bolt 4:10 Posi
Re: BB Swap Pics
Wow what a beast any 1/4 mile times? Beautiful job man
Old Aug 4, 2008 | 09:47 AM
booboosean's Avatar
Car: 1989 Camaro RS
Engine: 396 BBC
Re: BB Swap Pics
Thanks, I appreciate it!! I haven't run it at the track yet. We have an 1/8th mile track about 10 miles from my house. I'm ready to take it up there and run it. When I built the car, I was shooting for mid 11s in the 1/4. I think it will do that. It hooks really hard with the M/T tires on the street!!
Old Aug 4, 2008 | 08:38 PM
Engine: 350 4bbl
Re: BB Swap Pics
dude if that big block is built (which it looks it) I think you'll be surprised if it'll hook up out of the box, my 82 Z has a 350 .40 over with a .632 gross lift cam, headers,edelbrock intake and a holly 750dp and I'm usually around 11.50's. My buddy has a 454 in his 87 T/A and it's just a bolt on car and he's deep into the 10's
Old May 20, 2009 | 07:25 PM
LOWNTUBD's Avatar
Car: 82 Trans Am (92 Front Clip)
Engine: 454 BBC
Transmission: TH350
Axle/Gears: 4.55
Re: BB Swap Pics
Hi Boo,
Sent you a message before i saw this thread. Again very helpfull!! Just one dumb question...
I'll be using a CSR electric water pump and the Alan Grove 236R bracket will do the trick... The PS bracket 418L looks like the trick as well... but here is the question... what crank pully would i use. My assumption is a long water pump 2 groove and i also assume the alternator hits the outside groove and the PS pump hits the inside? Am i all wet?
Old May 21, 2009 | 07:43 AM
booboosean's Avatar
Car: 1989 Camaro RS
Engine: 396 BBC
Re: BB Swap Pics
Originally Posted by LOWNTUBD
Hi Boo,
Hey LOWNTUBD, I replied to your PM, but I will paste it here too for anyone else who is interested.
My set-up is a mixture of a few brands (as you read). All the pulleys I used are Billet Specialties. I wanted something that looked good and they were a lot less expensive than March. All are for long water pump. I used their two groove crank pulley, and single pulleys for the ps pump, water pump and alternator. The ps rides on the inside and the alternator rides on the outside. The alan grove brackets are for long water pump also, so the alternator (even though it's a low mount) is on the the same plane as a standard upper-mount bracket.
They should work fine for an electric water pump. You'll just have to use much shorter belts.
Old May 30, 2009 | 09:27 AM
LOWNTUBD's Avatar
Engine: 454 BBC
Transmission: TH350
Axle/Gears: 4.55
Re: BB Swap Pics
Thanks Booboosean for all your advice. I reseached all i could and in the end... decide to throw money at it and go with the March set up (PN 23007 kit for electric pump)
I added it up and by the time i had steel parts plated or bought chrome parts separately, it would only be a couple hundred difference. Frankly the parts from March look great and go together great.
I went with the headers you suggested (patriot H-8012-1) coated. they are really nice. Thick flange at the head... nice!!!
Here is a pic of the motor as it stands today. It's all done save the accesories i'll be moving over from my existing SBC
https://www.thirdgen.org/forums/pict...pictureid=3972
FYI the swap process will begin when i get back from vacation Mid June. Here is a pic of the car from a show last nite.
https://www.thirdgen.org/forums/pict...pictureid=3976
Thanks again
Old May 30, 2009 | 09:29 AM
LOWNTUBD's Avatar
Engine: 454 BBC
Transmission: TH350
Axle/Gears: 4.55
Re: BB Swap Pics
here's a bigger pic of the car in a collection
https://www.thirdgen.org/forums/pict...pictureid=2647
1984HO
Mar 19, 2021 11:59 AM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
aaron7
Aug 17, 2016 06:02 PM
theshackle
Aug 22, 2015 06:52 PM
cstrobel65
Aug 15, 2015 10:19 AM
