tbi - carb??
Old Nov 18, 2008 | 05:35 PM
imRICH23's Avatar
Car: 88 vert iroc & 95 586hp trans am
Engine: 355
Axle/Gears: 373
tbi - carb??
swapped out old motor and installed carb... but it wont run. my 88 had the fuel pump in the tank, and the other motor i dropped in has it on the block. i was told to just get a fuel regulator. but it still wont produce and gas from the tank. i replaced feul pump on the black along with the filter.. and suggestions?
Old Nov 18, 2008 | 06:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Is the in-tank electric pump getting power? Is it producing pressure?
Old Nov 18, 2008 | 06:19 PM
imRICH23's Avatar
Engine: 355
Axle/Gears: 373
Re: tbi - carb??
i was told if you can hear the fump turn on it works... if thats true, then yes.
Old Nov 18, 2008 | 07:27 PM
five7kid's Avatar
It means it's getting power. It doesn't mean it's producing pressure.
Old Nov 18, 2008 | 07:48 PM
imRICH23's Avatar
Engine: 355
Axle/Gears: 373
Re: tbi - carb??
not sure exactly, but when i take the fuel filter off, its full of gas
Old Nov 21, 2008 | 05:08 AM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: tbi - carb??
If I remember right, the pump will quit after about 2 seconds, and stay off until recieving a signal from the ECM. I'm not sure if it's right, but I had the same problem with my car. I took out the old pump and made a pickup to go in place of it, then used another pump. The mechanical one on the block should suffice.
Old Nov 24, 2008 | 08:41 AM
imRICH23's Avatar
Engine: 355
Axle/Gears: 373
Re: tbi - carb??
which pump? motor or in the tank? and what do you mean by a "pickup to go in place of it"?
Old Nov 24, 2008 | 11:40 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: tbi - carb??
Have you never pulled the pump out of a camaro tank? You can't pull fuel through an un-powered electric pump, unless you drill the guts out.
You can direct wire 12 volts to the pump from an ignition hot, and then make a loop between the feed and return lines in the engine bay. The feed is larger than the return, so you can then use a plastic T in the loop, to feed the carb. This worked fine for my '88 Camaro when I replaced the TBI 305 with a 300 horse 350 with a Q-Jet. This works because the return is smaller than the feed.
Old Nov 24, 2008 | 05:19 PM
imRICH23's Avatar
Engine: 355
Axle/Gears: 373
Re: tbi - carb??
any pics of this?
Old Nov 25, 2008 | 11:16 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: tbi - carb??
Sorry, that car is long gone.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
