Motor Mounts
Old Jan 25, 2009 | 07:44 PM
beaner67's Avatar
Car: 90 RS
Engine: LT-1 350
Transmission: Auto 700R-4
Motor Mounts
What motor mounts will I need to drop an 85 350 carbed in my 90 RS (original 305)?
-G.
Old Jan 25, 2009 | 08:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Motor Mounts
Use the mounts from the 305.
Old Jan 25, 2009 | 09:09 PM
Reed35's Avatar
Car: 84 Trans Am
Transmission: TH350
Re: Motor Mounts
The 305 mounts should be the same as the 350 mounts. You can literally bolt it right in without much hassle.
Old Jan 25, 2009 | 11:42 PM
beaner67's Avatar
Car: 90 RS
Engine: LT-1 350
Re: Motor Mounts
Sounds good...
Is there anyway I can check to see if either is broken without having to remove the engine? I ask this question because i'm rebuilding my 350 which is already in the car and when I get the rebuild done I will be doing it in a place where there are not parts shops in case I need them. Is there anyway I can check or will I have to wait until I get it out for the rebuild?
Old Jan 26, 2009 | 12:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
This design doesn't "break" (although the transmission mount does). However, the engine mounts do sag, so the typical fix is to install polyurethane inserts in the half that mounts to the crossmember.
Old Jan 27, 2009 | 10:05 PM
Mike Massey's Avatar
Re: Motor Mounts
its a little trouble but install the poly mounts
Old Jan 28, 2009 | 11:53 PM
beaner67's Avatar
Car: 90 RS
Engine: LT-1 350
Re: Motor Mounts
Anyone have a web-link for what I need? I just want to make sure that I'm getting exactly what I need
Old Jan 28, 2009 | 11:57 PM
myroc86's Avatar
Car: 86 Camaro
Engine: 350 LT1
Re: Motor Mounts
Or you can go solid mounts
Old Jan 29, 2009 | 06:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Motor Mounts
http://www.spohn.net/shop/1982-1992-...s-SBC-BBC.html
JamesC
Old Apr 17, 2009 | 09:31 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Re: Motor Mounts
I just read a few posts stating that solid mounts are not that good for everyday street use. Something about parts/bolts shaking loose.
Old Apr 20, 2009 | 10:27 PM
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
Re: Motor Mounts
Dont mean to hijack the thread BUT
I did a search for motor mounts and after page one gave up.
Any one have a link on how to swap in poly mounts im going to be doing that sometime next week and have an idea on it but not exactly.
Old Apr 21, 2009 | 05:06 PM
five7kid's Avatar
You have to remove the mounts from the crossmember. That's the same regardless of which type of inserts you use.
How to install them in the clamshell is provided in the instructions that come with the inserts. You have to drill out rivets, for one thing.
Old Apr 21, 2009 | 07:29 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Re: Motor Mounts
Where are you guys buying them? I know Summit has them.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
