can i fit a 350 ram jet in my 82 camaro
Old Aug 30, 2009 | 07:18 PM
82_Camaro's Avatar
Car: 82 Z28
Transmission: Turbo 200C
Axle/Gears: 3.43
i have an 82 camaro with a 305 crossfire. i want to put a 350 ram jet in it. can i fit it in. i want the GMPerformance crate engine part #12499120.
please let me know if you think that will fit. thanks and can i bolt up my trans to it
Old Aug 30, 2009 | 07:52 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: can i fit a 350 ram jet in my 82 camaro
of course, the only problem you may run into is hood clerance but i think it should fit fine. other than that its the same physical size as your 305
Old Aug 31, 2009 | 09:38 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
It fits under a stock hood, no problem.
Old Aug 31, 2009 | 03:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
http://www.gmhightechperformance.com...ure/index.html
Old Aug 31, 2009 | 06:43 PM
82_Camaro's Avatar
Car: 82 Z28
Axle/Gears: 3.43
how about possibley a zz383
Old Aug 31, 2009 | 07:17 PM
Stephen's Avatar
Car: 87 GTA
What intake?
From a 283 to a 400, there is no physical size difference on the outside, short of the height if the chosen intake. And carb/air cleaner, for those engines equipped.
Old Sep 28, 2009 | 01:54 PM
jimcairns's Avatar
I have one in my 1988, a project that doesn't seem to finish itself, or allow me to do it either. Engine fits just fine, but the headers (Hedman) are very tight on the AC/Heater box, Hedman says I have adequate clearance, but I expect the plastic will either get very hot or melt. Can't find a relatively easy fix, so if someone else has a idea, please let me know. The problem seems to stem from the Vortec vs standard heads. Maybe it's just me since I haven't done anything like this before.
Old Sep 30, 2010 | 08:08 PM
dyflrd's Avatar
i put one in my 1990 1le.. i crated the original engine and tranny cause mine is one of 24 made that year with the 350 and i want it to be numbers matching if i ever do sell it... but i had to put a cowl hood on because the intake was rubbing slightly on the original. i got the car for 3k and have done a 13k$ restore on it. its not forsale, but offer the right amount... it is a SUPER RARE car.
Old Sep 30, 2010 | 09:20 PM
DemonYusuke's Avatar
Car: 1991 z28 L98 Spec
Engine: 5.7 350 TPI 245\345
Transmission: 700 R4
If you believe your gonna melt some plastic with your headers, i would recommend, if Im not mistaken its ceramic heat wrap specifically for headers, it reduces the heat dramatically, I know its used on Motorcycles when the pipes are to close to your legs, its supposedly cool to the touch 30 seconds after the engine is turned off.
Old Dec 18, 2012 | 08:57 AM
dyflrd's Avatar
yes you may have a problem with hood clearance. had to get a cowl because of 1/2-1" clearance issue on te intake.
Old Dec 18, 2012 | 05:12 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
He probably figured that out, 3yrs ago when he posted.
Old Dec 18, 2012 | 05:21 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
L98GTA87
Aug 11, 2015 06:55 PM
bryan623
Aug 10, 2015 11:33 AM
