92 lingenfelter ZR1 vette motor swap
Car: 1989 GTA
Engine: pending install 383 tpi
Ok here is what i have, I was given, yes , given a 92 lingenfelter zr1 motor with all wiring down to the ECM and the digital dash can anyone point me in the right direction for wiring diagrams to swap this motor into a 91 Formula?
Re: 92 lingenfelter ZR1 vette motor swap
Now that's piece of luck ! Try this place...expect to throw money, and post progress. http://www.speartech.com/
Car: 1989 GTA
I dont really have to worry about the aftermarket support Lingenfelters shop is only two hours away and the tuning shop they use is about the same distance. After i get a gasket refresh done on the motor and new oil pump the only thing i plan on doing is stroking and tuning. Thats all the same basic stuff as any SBC
1 Post
Car: 92 Z28
Engine: Boosted LSX
Its been done in a camaro before.
http://www.gmhightechperformance.com...aro/index.html
http://sportscarforums.com/f19/100k-camaro-30291.html
http://www.lemonfree.com/34710394.html
Car: 1989 GTA
really? according to Lingenfelters shop a standard 383 1pc rear main assembly can be used in that block. where are u getting your info id like to read up some more on that motor. thanks for the input
1 Post
Car: 92 Z28
Engine: Boosted LSX
yep, ya beat me to the punch.
http://www.zr1netregistry.com/ZR1_about.htm
LT5 engine, an aluminum-block V-8 with the same bore as the standard (L98) 350ci displacement unit, but with 375 horsepower. To accomplish this power boost, the new block featured four overhead camshafts and 32 valves. The LT5s were built by Mercury Marine in Oklahoma and assembled into the ZR-1 vehicle at Bowling Green.
1 Post
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
They actually didn't have the same bore size, but they had the same bore spacing. The motor is all together different than a regular SBC.
Car: 92 Formula 350
Transmission: TH700R4
Axle/Gears: 3.23 posi
subscribing. I really wanna see lots of progress pics and stuff for when this swap actually happens. It's been done before, but actual progress pics will definitely be neat
Car: 1989 GTA
ya thanks for the info its been a big help, ill look more into the motor itself before i make a decision
1 Post
Car: 92 Z28
Engine: Boosted LSX
Just drop it in as is. How many miles are actually one it? What happen to the car it came out of?
Pic's of LT5. what year engine is it?Any pictures of the car its going in?
Car: 1989 GTA
it has 46343 miles and the car was rear ended by a dump truck
Car: 1989 GTA
nothing has been done to the motor yet. I am waiting to get back from Iraq before I decide on anything. Lingenfelter quoted 8 grand for tweaking and the tuning guys quoted 500. But it also depends on which motor I have. They told me they didnt serial their builds until 2002 so Im waiting on the cars VIN so they can tell me what exactly has been done to the motor already.
Car: 1992 camaro
Axle/Gears: 3:73
There was a fellow over on tech a couple months ago put a LT5 in a 84 vette and a couple turbos. He had $3200 alone in 4 custom cams
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
did this ever get built?
i got to drive my uncle's Haibeck tuned 92 ZR1 last fall- even with a dyno chart that shows 450HP at the wheels, it didn't impress me all that much..
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
You are hard to impress. I have a 90 that makes 430 to the rear and winds forever and it is one of the greatest engines ever designed. That much power with a smooth idle and perfect street manners. Cams with only 390 lift and flow over 300CFM.
