motor swapping gurus I need your help!
Old Oct 17, 2000 | 04:18 PM
85cam's Avatar
Car: 92 RS
Engine: 396 sbc
Transmission: t5
As most of you know I finally found me a motor worthy of going into my 85 SC
350, supposed to be tuff with all the stuff done to it, but my question is
When I am pulling the 305 out and keeping my 700r4 what do I do with the computer?
I am running a vacuum advance distributor and a holley 750 double pumper, so what do I do with my computer? DO I need it for anything? What about the torque convertor lockup? How do I go around that?
All your help is appreciated!
Jason
Old Oct 17, 2000 | 04:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Why? Keep the computer-controlled pieces. At most you'll have to tune your secondaries, but that will be a lot simplier than tuning a Holley DP and mechanical distributor. And, your TCC lockup will continue to work.
If you insist on doing it, you can either hook up a toggle switch (see tech articles), or get a lock-up kit from Summit or Jegs. Your SES light will come on all the time, so take the bulb out.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Oct 17, 2000 | 04:30 PM
85cam's Avatar
Car: 92 RS
Engine: 396 sbc
Transmission: t5
ONE REASON
Computers suck, well 3 reasons
Computers suck
My QJ is on its last leg
and I bought the Double pumper already
So all I need to do IS
Rig the lockup then right?
Thanks 5.7Kid thanks alot!
Old Oct 18, 2000 | 01:22 PM
MILT's Avatar
Hey, you don't even have to run the TCC. You should, but if you don't it doesn't really matter, although it will generate more heat. On one car I just left it alone, and put in a tranny cooler.
Old Oct 18, 2000 | 04:35 PM
Baz89RS's Avatar
Me too, i replaced my 305 TBI motor with a 350 bored .060 with 10.3 compresion and the edelbrock RPM perf package. Never installed the switch only a trans cooler...
Old Oct 18, 2000 | 06:42 PM
five7kid's Avatar
Well, not to flame or anything, but computers can be your friend, if you're willing to be their friend.
For what you've spent on the DP and what you still need to spend on a distributor, you could get that q-jet fixed up. You'll also have to get a manifold that will mount the square pattern DP, unless the 350 already has that, or an adapter to go from spread bore to square. Adapters REALLY suck.
I'll get off your back now. Just want to be sure you've considered all the options.
Oh, my TCC doesn't lock, for reasons I haven't discovered, and my tranny hasn't burnt itself to crisp yet. Course, it's mostly stock for now. Will be taken care of when the engine's gotten its steroids...
Old Oct 18, 2000 | 06:59 PM
85cam's Avatar
Car: 92 RS
Engine: 396 sbc
Transmission: t5
well I got everything already
vacuum advance dist. square bore intake and everything
I am fine there
I just need to know what I could need to keep the computer for!
Nothing it seems!
Thankis so much guys!
Old Oct 18, 2000 | 10:07 PM
S92RS's Avatar
I got rid of my computer. Actually it's still in the dash, but not hooked up to anything. If I ever do hook up a computer in my car, I'll be running FI. I swapped converters because I wanted a higher stall speed, and installed a tranny cooler. My new converter is a non-lockup, but it shouldn't matter.
- the 92 RS is gone..
- 1984 Z28 with 89 bumpers and ground effects.
- 355 with ported World S/R Torquer Heads, 214*/224* .471/.496 lift cam, Crane 1.6 Full Roller Rockers, 2500 non-lockup stall converter, Holley 750 carb, Edelbrock Performer intake, Hedman headers with custom 3" Flowmaster exhaust, Lakewood LCAs, Powertrax Locker with 3.23 gears.
- http://s84z28.fbody.com
Old Oct 19, 2000 | 09:28 AM
five7kid's Avatar
One thing that may not work is your cruise control. Not sure what year it started, but at least my '86 uses the VSS signal and the ECM to run the cruise. Without the engine signal, I'm not sure the cruise will work, if yours is of the same variety.
Old Oct 25, 2000 | 11:19 PM
ProblemChild's Avatar
I'm gonna be the ******* here. Anybody that ditches a Q-jet for a pos Holley is either lazy or stupid. And yes, that includes the electronic version (that one in particular.)!!! The stock carb. has more adjustments built into it than any holley or carter ever created. Does it take time to fine tune? Yes. Does it take effort to fine tune? Yes. Is it worth it? Hell Yes!!! You will never get a holley and a vacuam dist. to perform as well in street/strip as you can the stock setup. Doing it correctly you will get better drivability, better mileage, and,within a tenth e.t.,using the CCC parts. Just my professional and personal experiance.
Torque is KING!
All pray to the god of grunt! When ye thinkth ye has been whupped than shall ye meet the mighty Buick! For none can surpass her majestic power, and all will yet try. All pray to the god of grunt. For the King of torque has arrived!
1. 82 Camaro+ 1. 455" Buick+ 1. N2O plate = YOUR WORST FRIGGIN NIGHTMARE!!!
Da Problem Child
ProbChldR@aol.com
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
