Lt-1 swap info
Old Jan 7, 2001 | 11:35 AM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
Lt-1 swap info
I am going to be putting my Lt-1 in this month. I was woundering if anyone had pictures of what has to be done to the frame/engine mount to keep the ac?
Thanks, Kory.
Old Jan 7, 2001 | 02:42 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
LT1 or LT-1, there is a differnce. LT-1 being the 1970's version and LT1 being the post L98 small block.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 226/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter.
13.24@104
Old Jan 7, 2001 | 03:28 PM
85ws6TA's Avatar
Car: '92 Typhoon/ '79 Vette
Engine: Turbo 4.3L/Forged 355ci
Transmission: 4l60/th350
Just like the 2000 LS6 and the early 70s LS-6 right? Who cares? if somebody says im putting a LT-1 in my car we know then mean post L98 because noone in thier right mind would pick a 70s LT-1 over a 90s LT1.
sorry to be an A-hole, but why get technical?
1985 WS6 Trans AM
glass T-tops
bone stock sloth of an engine LG4
T-5 tranny. thank god, i couldnt stand an LG4 auto.
Plans for an LT-1 or LT-4,
also plans for dual flowmaster exaust.
Got a corvette when i was 16, paid for it myself, screwed the engine up (idiot light didnt work, and i trusted the guy when he said he just changed the oil), and it turned into a project car.
now my TA is my daily driver. not a bad one, but it needs to be faster.
Old Jan 7, 2001 | 03:59 PM
Brian92RS's Avatar
My thoughts exactly.. I would imagine that if he was putting the early 70s LT1 in, he would just say that he's putting a 350 in.
1992 Red RS with 305 TBI
Old Jan 7, 2001 | 06:49 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
www.hpsalvage.com/3rdGen.htm has an article on this that should be helpful.
Old Jan 7, 2001 | 08:04 PM
jms's Avatar
jms
Let me say this as nicely as possible and I'm not trying to start a flame war. If you didn't have to meet emissions, the 1970 LT-1 would be a great engine in anyones thirdgen f-body. 370 GROSS horsepower (Corvette or 350 horse in Z-28 with the main difference being exhaust manifolds and Chevy's reluctance to have lesser cars rated near the 'Vette) at 6000 rpm (5600 in Z-28), 380 lb. ft torque @ 4000 rpm (380 @3600 Z-28). 11:1 compression, High-rise aluminum intake, Holley carb, 2.02 intake, 1.60 exhaust heads, solid lifter cam (.450 something lift), steel crank, 4 bolt mains, big balancer, etc. GRANTED, these are gross rated power figures, but the 1972 LT-1 using today's method of rating power still managed 255 horses with just 9:1 compression. An original LT-1 would be an excellent engine if you didn't mind the high compression of the 1970 version. It is also a VERY strong base for building a much more powerful engine. The power figures I'm quoting are out of my 1973 Chilton's Manual. I have also driven and raced vehicles with the 11:1 LT-1 back in the early 70s when there were a few on the streets. I also realize the original post was most likely about the newer LT1 but just imagine, if you didn't have to meet emissions, what fun a 6000 rpm solid-liftered small block could be.
jms
Old Jan 7, 2001 | 09:20 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
my thoughts exactly jms. I wouldnt have said it just to be a ******!
Old Jan 8, 2001 | 09:19 AM
TexasLT1's Avatar
Car: '92 RS
Kory, I did this swap (LT1) and wanted to keep my AC, so on the front of the crossmember just above the engine mount, you have to notch about a 3 inch wide by 2 inch deep hole into it. but dont make the mistake I did, you have to weld 1/4 steel into the hole, not 1/2, I had to grind most of mine down on the bottom. e-mail me and I can probably get some photos for you if this was confusing
-'92 RS with self-installed '95 LT1
-Heddman Headers
-TPIS throttle body airfoil
Kills
-'98 V6 Camaro
-'89 5.0 ****stang
-'97 Sebring
-'96 ****stang Cobra
Losses
-'99 Mustang GT
-'96 Mustang Cobra
Old Jan 8, 2001 | 05:44 PM
Car: 88 Iroc
Transmission: t 56
Thanks guys, I think that I have all the info I need.
Kory
AussiePr0nCar
Mar 6, 2020 04:04 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
cRoe4
Aug 7, 2015 08:46 PM
