Post your cam specs.
Old Oct 22, 2009 | 05:36 AM
327sleeper88's Avatar
Car: 1988 rs
Engine: 555BBC; Dart, Lunati, SRP, Howards
Transmission: ATI TH-400
Axle/Gears: 35 spline 9", locker, 3.00's
I want to know what kind of cams you guys are running in you "street" car. Anyone running a ridiculous cam on the street?? I want to know how it is and if the the trade off is worth the power.
mostly interested in sbc's weather it be 305,327,350,383,400
lets see what you got!
Old Oct 22, 2009 | 11:26 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Post your cam specs.
I've personally run cams over .600 lift and 240 duration on the street, in engines from 350 to 500 ci, and those days are over. If you're 18 years old, then I'm sure you'll try it no matter what you're told, but when you're ready for power you can drive, you'll either do a 383, an LSx, or a 350 with boost. Boost on the LSx is a natural, but then you end up with traction problems all the way past 100 mph on drag radials.
Old Oct 22, 2009 | 11:31 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
218/224 @ .050 at around .470 lift
Thats a pretty tame cam... I want to go bigger. but I dont think I'll go past 230/230. I just dont like the idea of having to spin my motor to 6500 RPMs to get the most out of it. Being able to shift at 5500 isnt always a bad thing.
Old Oct 22, 2009 | 02:29 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Had a 212/222 109 LSA cam in my old Carb'd 350 w/ vortec heads, at any time I could stomp it and have power. Pulled no problem to 6k.
Ran the Biggest crane compucam in 350 TPI motor, I can't remember the specs exactly I know it was a 114 wanna say 218/226 with mid .4xx lift. Insane torque from Idle and felt pretty powerful til 4500 in typical TPI fashion. Had 2.73 rear in it and I could only get to about 125 before the cam. I could bounce the needle off the trip reset after I put the cam in. Raced my buddy's BMW 535 a few times, the told me his speedo said about 260km/h when I topped out, converts to about 160 mph. Before anyone get's there thong twisted that was done on the autobahn in germany.
I run a 224/224 .563/.563 112LSA cam in my 2000 Trans am. Bet your *** it's quick, but really doesn't come alive til nearly 3k then rips to 6200 where I have the rev limiter set. LS1's aren't known for there low end in the first place though.
Old Oct 22, 2009 | 05:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
ZZ4.
Old Oct 22, 2009 | 07:03 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
222/230 at 50 with 509/528 lift 112 daily driver
Old Oct 22, 2009 | 07:39 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
211/221 @ .050 with .442/.465 lift 110 LSA
It's just a fun weekend car that I drive to work every once in a while.
Old Oct 26, 2009 | 08:33 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Currently comp roller cam 242/248 .52/.562 110 lsa in my 383. Very streetable cam (IMO), like it quite a bit. I may switch back to my old cam 238/242 .52/.54 110 lsa because I think that cam actually produced more power with my current setup.
Old Oct 26, 2009 | 08:41 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Comp XR282HR-12 230/236 .510/.520 with a 112 LSA in a carbed 350.
Old Oct 27, 2009 | 08:09 PM
lillis375's Avatar
Car: 1989 Camaro
Engine: 355
Axle/Gears: 9 bolt 3.45
comp cam 250/256 .519/.523 110 LSA drive it just about everyday it my baby, not a dd but drive her alot
Old Oct 27, 2009 | 09:37 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
CC .510 .541
230 245 @ .50 on 1.6 rockers final lift .540 .571
runs flawless 50 # injectors set at 44# 40PSI ( perfect mixture )
Stealth ram with 1206 intake ports .125 domes 64CC heads 2.02 1.06
Old Nov 5, 2009 | 12:12 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Stock L03 Cam - 179/194@50 .350/.384 Lift
Old Nov 5, 2009 | 09:04 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Same here but with 1.6 rockers.
182/197@50 .385/.410 Lift
Soon I will have a ZZ4 cam with 1.6 rockers on the intake and 1.52's on the exhaust
210/224 @.50 .506/.517
Old Nov 7, 2009 | 07:40 AM
SeanW's Avatar
My 350 has a comp extreme energy split pattern cam. 230/224 duration at 0.050 lift. 110 LSA. 477/480 lift with 1.5 crane roller rockers.
My 383 i am running a comp extreme energy mechanical roller. 236/230 duration at 0.050 lift. With 1.6 harland sharpes it yeilds .588/.601" lift respectively. With this cam, 11.13:1 comp, and Canfield 215 heads i am pulling 18" of vacuum at idle.
Old Nov 7, 2009 | 07:58 AM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
239/242, .649"/.609" 111 LSA
Old Nov 7, 2009 | 08:10 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
218/228 .492 .492 on a 112lsa on a ported edelbrock/slp tpi with l98 heads..... has very good power all around.. makes for a fun daily driver...
Old Nov 7, 2009 | 10:46 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Last 383 was 248/252 @.050 with .540/.562 lift on a 112 LSA. BEAT the rev limiter at 7k RPM, but i did not have to go that high if i didnt want to.
Old Nov 8, 2009 | 05:28 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
small mech roller comp cams
236/242 @50 602/608 1.6 rocker
good vac.. lots of power.. good till 6200rpm
street strip car.
427 sbc 11.5.1
Old Nov 11, 2009 | 12:03 AM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
isky hyd roller cam, 225/234 @ .050 .505 int . 530 exh lift 115 lsa.. goes good with my roots blower setup
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
80s Poncho
Aug 19, 2015 06:45 PM
Fronzizzle
Aug 9, 2015 01:15 PM
