305 to 350 TPI
Old Apr 17, 2001 | 03:33 PM
camaro6spd's Avatar
305 to 350 TPI
ok, I want to talk to someone who has done this swap and has photos/information about it. I found and IROC with a 305 TPI but the 305 needs to be replaced. I have a buget of about $700. I have the ablitlity to rebuilt the 350 engine but i don't want to rebuild the 305 b/c it is not worth it. What do you guys suggest buying???
My GOAL....
A IROC-Z, TPI 350 with 350 hp backed buy a T-56 , 4th gen rear end and 1LE Brakes.
Old Apr 17, 2001 | 05:33 PM
91B4C jacob's Avatar
if you look down the page you will see I just did this post and I got hardly any response so good luck man
Ya sure it is just an RS
B4Cyaa
1991 RS B4C
Former Nebraska Highway Patrol Car
305 TPI
WC T-5
Four Wheel Disk Brakes
Only Options
Rear Defrost
Am-Fm Radio
Red-int White-exe
One BA Of A 350 In The Works
Mods
Dynomax Cat Back (to hold me over till I got the $$$ for the Borla)
best 1/4mile Run of 14.92@94.83
with 145,000 on her
god speed dale
Old Apr 17, 2001 | 06:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
91B, I thought I spent a good bit of time on a well-thought-out reply, and all I get in return is this...
Okay, 6spd, let's see what we've got here. What 350? You don't say what year your current car is; or is this a car you don't have yet? Are you getting parts only from this IROC, or the whole car? What 350? What's wrong with the 305?
As my most recent reply to 91B says in his referenced post, you ain't gettin' much for $700. Flat out reality. You may be able to re-ring the 305 for that, but getting something new and rebuilding it for 350 HP is beyond realistic.
A GM replacement 350 for around $1200-1300 is closer to your budget, but would only put out about 250 HP. Your HP goal NEEDS headers and high-flow exhaust; unless you go with the ZZ4 conversion kit, which has high-flow manifolds & exhaust - $5000 by the time you get it installed. Any other 350 combo will need good heads, which will run you about your budget alone, minimum, unless you come across a "find".
I would suggest you continue saving your money, continue to do research, look through magazines and catalogs to get an idea what it takes. When it all comes together for you, do it.
Now, I'm going home to install that MegaShifter and PowerTrax in the '57. I've been waiting about 3 years to get them...
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" Hedders, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere w/open diff & slipping tranny. Daily driver while Camaro was being put together.
[This message has been edited by five7kid (edited April 17, 2001).]
Old Apr 17, 2001 | 08:20 PM
Blue91''s Avatar
To switch to a 350, you need to change the knock sensor to one for the 350, you need to change the prom in your computer to run it properly and you may want to change your injectors,the 305 uses 19lb/hr and the 350 uses 22lb/hr stock but some people use the 19s anyway with an adjustable fuel presure regulator.Other than that the two engines are basically the same on the outside so all you accessories will bolt up.Aside from performance upgrades thats about all the difference there is as far as swaping the two.I dont know about the MAF sensor so if someone else knows please reply.Hope this helps
Old Apr 18, 2001 | 07:28 AM
camaro6spd's Avatar
thats is my long term goal, the 305 is junk, i have not bought the IROC yet, I am just trying to figure out what it will cost. I want to put a 350 in, inplace of the 305.
Old Apr 18, 2001 | 09:22 PM
camaro6spd's Avatar
no, the 350 would be used and I will rebuild it, hopefully a roller-motor. OK, say I get the 350 running fine, runs like it is a new stock L98. What first mods do you recommend to free up the most power, I know I want to add a Cat-back just for the shear sound and the performace gain, so...lets say I have a stock, perfect running 350 with a Hooker Aerochamber Cat-back. What should I do next.
Maybe the TPIS Fast Pak and porting of the stock base and plenum. With those mods that is around...250 hp??
-Tom
[This message has been edited by camaro6spd (edited April 19, 2001).]
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
