Completed the 350 engine swap
Its in and running great. Only 12 weeks from decision time to completion. Some headaches and over budget on additional parts, but what
the H---. Its my Toy.
1987 Black Camaro IROC (orginal owner) Replaced LB9 @ 86100 miles.
New 350 Crate engine
Balanced & blueprinted
WP 67cc Heads 9.6:1 C.R.
Cam 450lift,216dur.@50,110
TPI Induction
22# Fuel Injectors
SLP Intake runners New Computer chip
K&N filters & Air Foil
SLP 1 3/4 Headers
3" Cat back exhaust
700R4 Auto
SLP Torque Converter (2400 stall)
Limited Slip rear (2:73)
245/45/17Z Tires
17x8.5 ATP Razze 5 Wheels
EST. 340HP
380#/ft of Torque
NEW TOY!
TPI Induction
22# Fuel Injectors
SLP 1 3/4 Headers
3" Cat back exhaust
700R4 Auto
245/45/17Z Tires
EST. 340HP
380#/ft of Torque
NEW TOY!
Headaches or kinks,well yes.
1) AIR tubes on the SLP headers.
2) Sensor fittings.
3) Oil leak at valve covers, center bolt covers would not fit heads. Stock 305 covers.
4) Starter getting fried by headers.
5) Minor assessories adjustments.
Nothing major.
TPI Induction
22# Fuel Injectors
K&N filters & Air Foil Hothkis STB
SLP 1 3/4 Headers
3" Cat back exhaust
700R4 Auto
245/45/17Z Tires
EST. 340HP
380#/ft of Torque
NEW TOY!
2) Sensor fittings.
Nothing major.
TPI Induction
22# Fuel Injectors
SLP 1 3/4 Headers
3" Cat back exhaust
700R4 Auto
245/45/17Z Tires
EST. 340HP
380#/ft of Torque
NEW TOY!
Car: 1985 Z28
Engine: 383 forged, B&M 144 supercharger
Transmission: Art Carr 700 R4
Axle/Gears: 9 Bolt G92
Congradulations, I have nearly the same combination and I love it. I'm also an original owner. I replaced the LG4 with a crate 350 in my 85 Z28 3 years ago @ 160K mi.Have since placed the 1 3/4 SLP hearders and Cat Back and added dual Cats. I have the WP heads but not installed. Have a B&M roots blower to add as well. The set -up in CHP mag ( 1999) showed 470 hp on the dyno. Now if I can only find a week off from work.
Thanks, glad I made the swap. Still working on minor problems.
Cam 450lift,216dur@50,110ls
TPI Induction(from 305)
22# Fuel Injectors
SLP Intake runners , New Computer chip
K&N filters & Air Foil ,
Hothkis STB
SLP 1 3/4 Headers
3" Cat back exhaust
700R4 Auto
245/45/17ZR Tires
17x8.5 ATP 5 Razze Wheels
EST. 340HP
380#/ft of Torque
NEW TOY!
22# Fuel Injectors
Hothkis STB
SLP 1 3/4 Headers
3" Cat back exhaust
700R4 Auto
245/45/17ZR Tires
EST. 340HP
380#/ft of Torque
NEW TOY!
Transmission: 4L80E/4L80E
On their tech sheets (available on their web site www.worldcastings.com), World Products states that the perimeter bolt bosses have to be ground down for center bolt covers to fit their S/R or Sportsman heads.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" Hedders, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere w/open diff & slipping tranny. Daily driver while Camaro was being put together.
[This message has been edited by five7kid (edited April 23, 2001).]
Thanks for the info. I e-mailed World Products and they said the perimeter Bosses
require grinding on the 1987 and later heads.
Will give it a try when I receive my new valve covers, they may have more clearance on the mating face.
Check web site for AllChevyEngines. The car is 1987 IROC-Z. Cost for install reasonable,
19 hrs Labor plus normal install parts. However; I spent too much buying extras. Like
I said, its a New Toy.
22# Fuel Injectors
Hothkis STB
SLP 1 3/4 Headers
3" Cat back exhaust
700R4 Auto
245/45/17ZR Tires
EST. 340HP
380#/ft of Torque
NEW TOY!
22# Fuel Injectors
Hothkis STB
SLP 1 3/4 Headers
3" Cat back exhaust
700R4 Auto
245/45/17ZR Tires
EST. 340HP
380#/ft of Torque
NEW TOY!
Terrell351
Jun 13, 2021 01:13 PM
theshackle
Mar 5, 2017 06:37 PM
