ZZ4... fuel injection.
Is it possible to put fuel injection on a ZZ4 Crate? I want to put a 350 with fuel injection. Although I was looking at something aside from the L98. I was planning on keeping the engine below $4k so the LS1 is out. Can the ZZ4 use fuel inj?
Thanks,
Jay
'91 RS 305 5.0L V8
All stock for now...
Thanks,
Jay
'91 RS 305 5.0L V8
Car: '89 Firebird
Engine: 7.0L
Yes. It's just like any other 350. The cam will work well with fuel injection. I had a Holley Projection system on a ZZ4. Just turn the key and drive away... no more warming up for 5 minutes before driving
[This message has been edited by QwkTrip (edited April 26, 2001).]
wbat about using my tbi for a zz4?
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood,tinted windows,MacEwen Overlays
Coming soon......"Custom" non-red material.
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I *think* the ZZ4 engine uses the Vortec heads. I know that TPI won't work (yet) but i beleive that there is an intake base that will allow you to use TBI. Check Sockin' Lockin' Dicky or whatever that place is called, i think he sells one.
<edit>
Here is the link to the place of the name i just butchered:
http://www.sdpc2000.com/
[This message has been edited by Omega (edited April 27, 2001).]
<edit>
- 89 Formula 305 WS6
SFC's
LCA's
Spohn Panhard Bar
Air Foil
Flowmaster Cat Back
Tranny Cooler
A/F Ratio Meter (not a mod but it sure spurs interest)
Trans Temp Gauge
Most "Free" Mods
3:73, Zexel Torsion Posi - 90 Eagle Talon 2.0
(Winter Beater)
Mods? Um, no
Car: '89 Firebird
Engine: 7.0L
<font face="Verdana, Arial" size="2">Originally posted by Omega:
I *think* the ZZ4 engine uses the Vortec heads. I know that TPI won't work (yet) but i beleive that there is an intake base that will allow you to use TBI</font>
Car: FORMULA 350
Engine: ZZ4
The tpi will work. I have done it. The zz4 has the pre-vortec bolt pattern. You would need an aftermarket lower manifold or a redrilled original. I am not sure about factory tbi though.
what do i need to make the 91 tbi work?
Transmission: 4L80E/4L80E
The ZZ4 does not have the exhaust cross-over passage in the heads, so the EGR valve needs to be fed via a tube from the exhaust manifold/header to the intake manifold.
The different angle center intake manifold bolts started in 1987, not 1986. The ZZ4 uses the pre-'86 bolt pattern (Vortec is completely different).
An '87-later intake can be made to fit the earlier style heads by elongating the center two bolt holes on each side of the manifold.
Either TPI or TBI can be made to work on a ZZ4. You aren't going to get the rated power out of it without some modifications to the induction, however.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/94.6 @ 5800' Bandimere.
92camaroJoe
Aug 13, 2015 06:07 AM
