engine swap + L/T's and TKO
Old Dec 27, 2009 | 01:18 AM
327sleeper88's Avatar
Car: 1988 rs
Engine: 555BBC; Dart, Lunati, SRP, Howards
Transmission: ATI TH-400
Axle/Gears: 35 spline 9", locker, 3.00's
I didn't know where to ask this question since it is exhaust, tranny, and motor swap.
I am building a 327 sbc with rhs proaction heads. I want to get hooker 2210 (1-3/4") and a TKO 500. has anyone done this swap? i would like to know if the are compatable.
I am spinning this 327 to 8000rpm, so don't want an automatic (for highway rpm purposes, and i like manuals)
would the crossmember for the TKO 500 get in the way of making a good exhuast with the L/T's?
thanks in advance.
Old Jan 4, 2010 | 03:19 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: engine swap + L/T's and TKO
If you study pics in the exhaust section of TGO, you'll see that it can be done with the 700R-4, and the TKO will give you way more clearance than the 700R-4.
Old Jan 4, 2010 | 03:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Shouldn't be a problem.
I can make you a good deal on a set of new 2210's. Where in Colorado are you?
Old Jan 4, 2010 | 03:39 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if you are spinning that high, forget the tko, they are not built to shift above 6500 rpm.
Old Jan 4, 2010 | 03:42 PM
AC's Avatar
AC
Car: Used to drive a camaro
I'm not running a 327 but I'm running the TKO600 and 2210's headers, along with a mufflex 4" catback
Old Jan 4, 2010 | 11:40 PM
Car: 1988 rs
what about 7000ish rpm? what manual tranny will shift 7000 rpm?
i am not going to be shifting that high very often, this is my temorary DD, then it will be my weekend warrior.
i might consider getting a 383 instead to make more power.
that mufflex 4".... is it a kit or just parts that you bought from mufflex?
Old Jan 5, 2010 | 09:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i would go with the 383. It will make more power, be more streetable and be cheaper than a 327.
mufflex setup is a complete catback, they even make a y- pipe for the 2210's to hook up to the 4" catback
Old Jan 5, 2010 | 11:52 PM
Car: 1988 rs
with a 383, will a good forged crank, arp main studs, scat rods, and KB forged pistons take 7000+ rpm?
Old Jan 6, 2010 | 08:18 AM
AC's Avatar
AC
I believe it would. I have no fear of pulling my motor to 7500 except for possible lifter float and my TKO. The rotating mass alone though I have faith would take it. 4 bolt, ARP Studs, Hbeam rods with ARP bolts.
Old Jan 6, 2010 | 06:50 PM
Car: 1988 rs
If i build a 383, i will want 500+hp and 500+ tq. are those #'s possible under 6500, n/a, on pump gas??? how often do you run into cam clearance issues with a 6" I-beam rod 383?
I saw a cool article called "mild to wild: ultimate guide to a 383 stroker"
the wild combo made 571hp @6900 and climbing, but they used a $3000 lunati rotating assembly.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
