Cheapest engine swap yielding most power
Old Aug 6, 2001 | 12:55 AM
One Eyed Jack's Avatar
I'm looking for 13s, yet retain daily driver gas mileage. I've seen it done. I want to keep at least 15mpg (currently 21mpg avg with my 305TBI). Tell me what i need and what I should do, etc.
Old Aug 7, 2001 | 12:26 AM
Hanks1's Avatar
<font face="Verdana, Arial" size="2">Originally posted by One Eyed Jack:
I'm looking for 13s, yet retain daily driver gas mileage. I've seen it done. I want to keep at least 15mpg (currently 21mpg avg with my 305TBI). Tell me what i need and what I should do, etc.</font>
Buy a motorcycle!!!
Old Aug 7, 2001 | 12:50 PM
mat89RS's Avatar
You could swap an lt1 like I did. gas mileage is good and it's about 300 hp . I've added headers and I have done the swap for 2500$ canadian, everything included.I had a 305 tbi before, the swap is not that hard to do .
89 Camaro RS Stock as a women with white panties
LT1 IS COMMING SOON.
Old Aug 7, 2001 | 12:59 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Chapest way to obtain your goal is N20 and a cam.
The more expensive route is of course bump up the cubes "327, 350, 383, 400"
It all depends of what amount of $$$$ you want to speend. $$$$$$=fast
SSC
Old Aug 7, 2001 | 09:34 PM
jamesbern's Avatar
If you can do all of the work yourself then I would say a 383. I will have all of 2000 dollars in mine. Of course I pay labor only to the machine shop as I don't have that at home. The engine I am building was built and dynoed in one of my magazines at 450 horse and 470 ft/lbs. torque. Not bad for 2 grand.
Old Aug 7, 2001 | 11:33 PM
MouseCamaro305's Avatar
l can run 13's in the 1/4 with a near stock 305. l've got runners, an exhaust, 150 HP nitrous shot and 3.73's with a few cooling mods like trans pan heat sink, synthetic gear lubes, and a rearend cover strenthener with heat sinks. l can still pretty easily get 15-17 MPG on the street and almost 20-24 mpg on the highway. the nice thing about nitrous is its there when you want it, and not when you don't. personally l think power adders are a really easy and good way to hit low strip numbers with high MPG. numbers. the downside to a blower is it's high initial cost, but the downside to nitrous is the high cost of keeping the frost in it.
good luck
Old Aug 8, 2001 | 01:43 AM
89formula422's Avatar
jamseburn, could you give more inf. on your 383. thanks
Old Aug 8, 2001 | 03:02 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
Amen...i want info on this engine build as well.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
