RETRO FIT ROLLER CAM
Old Jan 18, 2010 | 03:17 AM
stoning_volcom's Avatar
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
I have a question on how to instal a retro fit roller cam into a oldstyle block. I know its the same concept slip the cam in done deal not hard but how do i set the thrust is there to be any play? or none at all? nylon button? or aluminum? or does it matter? do i use a locking plate to hold the button into place? any answers would be very much appreciated. 86 corvette engine dont like flat tappet.
Old Jan 18, 2010 | 11:06 PM
SeanW's Avatar
Re: RETRO FIT ROLLER CAM
I run a cloyes two piece timing cover that comes with a built in button. You just set it to zero end play and then being aluminum when the motor gets hot you get your needed end clearance.
Old Jan 18, 2010 | 11:53 PM
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
well well that sounds like a good idea um,.... could you send me a link to one so i can buy it thanks. and by zero clearance how do you set it?
Old Jan 18, 2010 | 11:59 PM
SeanW's Avatar
http://www.summitracing.com/parts/CLO-9-221/?rtype=10
The button is adjustable with an allen key. It comes with instructions and gaskets.
Won't fit a short pump though without spacers.
Old Jan 19, 2010 | 12:03 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
I had the Comp XR270HR retro in a '77 350 block. At first i used the timing set and button that Comp supplied in the kit but ended up switching to a noisy gear drive and just used the button that came with it. never had any problems...
Old May 30, 2011 | 12:54 PM
fiveoformula's Avatar
Car: 1988 Formula Firebird
Engine: 5.3 LM4
Transmission: 4L65E
Axle/Gears: 3.42 True-Trac
I have a similar problem... Does a cam button work with a stock timing cover? Got an '88 roller block but the stock retainer plate won't work with my new Lunati cam, apperantly it's a retrofit-type and is flat on the front, like an old flat tappet style.
Old May 31, 2011 | 12:10 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Why don't you just get the proper cam?
Old Jun 5, 2011 | 10:56 PM
Engine: 5.3 LM4
Transmission: 4L65E
I didn't want to wait/send it back, but I decided that was the best thing to do so I sent it back. Ordering a regular roller cam from lunati tomarrow. Sucks because I didn't know it was a retrofit until I tore into my daily driver....
junkcltr
Aug 2, 2019 11:12 PM
camaro71633
Sep 1, 2015 10:24 AM
bdads
Aug 24, 2015 06:01 PM
anesthes
Aug 8, 2015 09:37 PM
