305TPI S/C
Old Sep 8, 2001 | 10:00 PM
buddman91rs's Avatar
305TPI S/C
im going to convert my TBI to TPI and bolt up a supercharger......im not going to 350.....what year should i get the TPI form and should i get the tpi off a 350 so i dont have to port it to make it flow decent? is there any company that sells the tpi system by itself and not charge out the *** ?
Old Sep 9, 2001 | 12:24 AM
ImportsRsloths's Avatar
305 350 TPI units are the same..... 350's have a different knock sensor ($20) and 22# injecters compared to 19#'s........ If you have a choice IT IS VERY WISE TO GET A SPEED DENSITY TPI SYSTEM (The maf system has a mass air flow sensor that will block A LOT of air the supercharger is pushing) the Speed Density systems were on all 90-92 TPI systems..... If you wanna see what im talking about look at a 89 iroc then look at a 90 iroc..... the 89 iroc has a sensor that calculates how much air is going in... not to mention its a $300 part when it goes! Best of luck! you got any more ?'s
Old Sep 9, 2001 | 11:50 AM
how much $$$ ? for the whole tpi setup fomr a 90-92 305? im gonna replace EVERYTHING in my 305 to TPI specs(as in cam, heads, everthing...) THEN once it runs good i will bolt on supercharger......
Old Sep 9, 2001 | 08:18 PM
firbird's Avatar
WHY??? would you spend all of that money just to make it just like a stock tpi especially getting a stock tpi cam heads and all of the other crap, they did not come with tbe best stuff in the world so i would not go around and look for stock heads and a cam of a L98 or a lb9 you would just be wasting you money and time, go and look for a different cam and heads. i have a tpi setup in my garage right now along with some tpi heads sitting in my room and a cam that is still in my engine that is in the back yard but i ask you WHY?? if you want a stock tpi get a new car....... a tpi car not a tbi car
Old Sep 10, 2001 | 11:11 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
if i were you i wouldn't go with the stock componets(cam,heads)you can get a set world products s/r 305 heads for less than $700 and you can find a good mild cam pretty cheap to if you look hard enough.
if your plan is to throw a S/C on your ride in the future you should put a fuel pump in that will support the S/C later when you do put it on.you will need to up-grade to a higher flow fuel pump for your TPI system anyway.
as for weather you should go with a speed density or maf?there are a few things you need to think about.speed density can produce more horsepower than maf but!speed density needs more ECM(computer)tunning than a maf system.a maf system is more flexable to climent changes
speed density systems are pretty hard to come by.GM only made them of for two or three years for that intake style.now you can change the maf system to s/d
if you are going to add a s/c to the mix i would try to find(if possible)a TPI system off a 91-92 GTA,T/A or a Z28!with speed density you have more options on how you want to run your air intake and getting the TPI off of a 5.7 you'll have the bigger injectors(22lbs)that should be enough to handle the s/c.
oh and the maf does not restrict air flow as much as most people think don't let that prevent you from getting a good deal on a cheap maf TPI system
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old Sep 10, 2001 | 04:25 PM
nebulous's Avatar
Car: 91-Trans Am-WS6
Engine: L05 350 - ATI 9psi
Transmission: Pro-Built:Street/Strip
I have(well until It blew, Im replacing with 350 now) a 305 TPI SC Trans Am. Stock heads and cam will work, and with a supercharger it is fast, but a cam designed with a supercharger in mind, and heads (possibly with a little lower compression) would make it soooo much better.
Old Sep 14, 2001 | 03:27 PM
ok, im going to buy a tpi setup at a junkyard it will cost less than 500 bucks with the computer and everthing(heads, cam) i will be doing this to my daily driver so i can only afford to have it not running for a day or so at the time.....i will convert FULLY to tpi and have it tuned and making the 230hp its supposed to so i dont have to deal with a whole bunch of variables (like if i put everything on at once) if it doesnt run right.....now after its running healthy i wil put in my order for a supercharger(im thinking of something between 8-12 psi) and i will install it over a weekend and get it running good......any suggestions on which company to get a supercharger from? and what rear end gear would be good? 3:42? 3:73?
1991 RS LO3
some of my favorite quotes:
I do not blame stupid people for being stupid, what i do blame them for is for not asking smart people for advice. When ever my mom asks for help, i tell her, i'm the one who knows what he's doing, not you, don't question me, just do what i tell you to. if stupid people would just realize they were stupid, and consult a smart person for advice, before they went and did something stupid and got pregnant/got someone pregant, this ****hole of a world would be a lot better. - adam corola
Honda makes great performance cars - any scarcastic comedian
Old Sep 14, 2001 | 03:30 PM
oh yes and also......world products s/r 305 torquer heads are in the works too(after s/c) also will call cam companys and get decent cam
1991 RS LO3
86iroczwv
Sep 3, 2015 06:21 PM
jbd1969
Aug 17, 2015 07:06 PM
rdog30
Apr 6, 2001 07:07 PM
bad camaro RS
Aftermarket Product Review
Feb 26, 2001 01:33 PM
Stell1579
Oct 11, 2000 10:47 PM
