Take engine and trans out as one???
Old Nov 24, 2001 | 08:58 PM
89blackbird's Avatar
I have an 89 GTA and this winter I am going to pull the engine and trans out to rework them.My friend says to remove them as one unit. Is this the best way to go? Should I put all the bolt on parts on the engine when I put it back? Which is easiest to bolt everthing on 1ST or put in the stripped engine and bolt everything after it is in? Thanks guys.
Old Nov 24, 2001 | 11:42 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
if you can, take them out as one, put all new stuff on the engine, get the tranny a makeover, put back together, then put back in car. Alligning the input shaft on the pilot bearing sucks when the tranny's allready installed.
$150.00 2.8 Auto.
short block now
turbo eventually, 3.4 may be in the future
Giving the enemy the opportunity to die for their country
Old Nov 25, 2001 | 02:06 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Pulling the engine and transmission together tends to be simpler than separating them; if you're going to be working on both it's highly recommended.
If you're going to do this you want to get a tilt-leveler to assist you with this task.
Old Nov 25, 2001 | 10:40 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i would definitely take them out as one. without a doubt.
just be prepared for the tranny fluid that will POUR out of the tranny what the driveshaft is taken out.
i wouldnt put that much on the engine other than the intake if i was you. especially the distributor because it can easy bump the firewall during installation and mess things up. also, i tried headers installed and it wouldnt go. all the accessory stuff should probly stay off too just because of clearance problems.
but, you can get away with the balancer..thats not a problem, and it will save you a fun tim of putting them on when the engine is already in.
-brian
1991 Camaro RS
GMPP 350 HO crate engine - 454 TBI, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
My car's webpage - z28boy.cz28.com
President - Central New York F-Body Association
Email - z28boy@twcny.rr.com
AIM - "Z28 Boy"
Old Nov 26, 2001 | 12:00 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Drain all fluids, including the tranny, before you start pulling them out. Use a tilt sling to help ease them out (and in, for that matter).
I had headers on for my last install, but the tranny stayed in this time (engine only). I had the exhaust manifolds on when I did the engine & tranny together. It might make a difference with header brand, but I don't think it would have mattered if I had been doing engine/tranny together with headers on. Certainly was easier than putting the headers on with the engine in the car.
I'd second the intake manifold on, distributor out. I put all sensors on as well, but not the starter.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Nov 26, 2001 | 09:05 PM
Thanks guys it gives me some good ideas to think about. If I buy slp headers can I bolt them on and then put the engine in?
Old Nov 26, 2001 | 09:31 PM
five7kid's Avatar
I take back that "all sensors" statement. The oil pressure sender sticks out in harm's way. Fairly easy to remove or install while the engine's in.
Old Nov 26, 2001 | 10:52 PM
fazool's Avatar
I just finished puting in a new engine in my '86 bird. Five7 dude gave me some good advice too. I left off everything during the install except intake and balancer and fuel pump (mechanical in my setup). Cover all the holes in the motor with duck tape or something suitable! Leave off the pressure sender gizmo, it'll break too easy.
As for headers, I bought the edelbrock TES and they slip in pretty easy. As it turned out for me, only the drivers side needs to be in place before installing the engine. The passenger side fits in with no problem once the engine is sitting on the mounts. I plan to install everything else a little at a time - no rush here.
good luck
gene
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Exxon Limited
Aug 9, 2015 08:13 PM
