$3500 for engine/install
Old Mar 11, 2010 | 01:27 PM
sethteef's Avatar
Car: 88 firebird
I am planning on getting a motor for my firebird. I contacted a engine shop somewhat near by and they said it would cost about 3500 for the engine and install. I think I will ask for some forged pistons
to go the motor as well so it will be a tad more. So is this price good for 330hp 350ci engine (before I ask for the forged pistons). Also I do not have the tools, room, or knowledge to do the swap myself. I wish I did though.
Old Mar 11, 2010 | 01:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Forged heads???
Old Mar 11, 2010 | 01:35 PM
sethteef's Avatar
Car: 88 firebird
Re: $3500 for engine/install
I meant pistons not heads, dont know how I mixed it up.
Old Mar 11, 2010 | 01:38 PM
five7kid's Avatar
Forged pistons would make more sense.
Are they building this engine, or is this the GM 330 horse 350 crate engine? Are you doing anything to the TPI?
What are your goals with the car after the engine swap?
Old Mar 11, 2010 | 01:45 PM
sethteef's Avatar
Car: 88 firebird
They are going to be building the engine for me. I am going to be switching over to carb setup for the motor. As for the old 305 tpi I have no plans for it. As for the car I plan on redoing most everything and then to try to make it around an 12 sec 1/4 mile car. So after the motor I plan on getting new rear end gears, then rebuilding the tranny, also refinishing the exterior/interior at some point and then back to the motor if I feel like it. I am planning on the motor for around the fall.
Old Mar 11, 2010 | 01:54 PM
sethteef's Avatar
Car: 88 firebird
And I got some more of the specs it should have on it, most of which dont mean alot to me since I dont know engines at all. Its a 355ci not a 350, .030 over cast pistons, moly rings, double roller timing set, 9.8:1 compression, 230 @ .050 hydraulic flat tappet cam and lifters, edlebrock victor jr. intake, 750cm holley double pumper, and a headers.
Old Mar 11, 2010 | 03:42 PM
five7kid's Avatar
Will you drive it on the street at all?
Any idea what heads they're putting on it?
Are they going to do the TPI to carb conversion? If so, I hope they know what they're doing.
What transmission are you going to run? With that much cam and a Victor Jr., you're going to need a pretty loose converter with an auto transmission, or steep gears with a manual transmission.
Old Mar 11, 2010 | 04:23 PM
sethteef's Avatar
Car: 88 firebird
The car is my daily driver and I would put on 150 miles a week or so. Right now the tranny I will run is a auto 700r4 thats in the car. I am not sure what heads they generally run on the engines but I will try to find out sometime. If there are a set I should get I can have the shop use them not the other ones. They will build it however I want as long as I have enough to pay for it. They would be doing the engine swap and the conversion.
Old Mar 11, 2010 | 09:07 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
If I were guessing,I'd bet that is the old Comp Magnum series 280H cam.It's pretty rowdy for daily use,and if they will only muster 330 hp from it,they aren't going to give you much for heads.I would advise questioning them a bit on the cam and intake choice.For a dd,I would think a milder cam and performer RPM style intake would give at least that much HP,in a much friendlier package.Also be aware that if you do end up using the Vic. jr.,you will most likely run into hood clearance issues.
Old Mar 11, 2010 | 10:02 PM
sethteef's Avatar
Car: 88 firebird
The cam should just be an oem cam. What kind of heads/cam should I try to get? They build the motor to however I ask. I would be fine with getting a cowl hood but what should get instead?
Old Mar 11, 2010 | 10:30 PM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
Don't make the mistake I did.
I installed a 355HP motor in front of a rebuilt TH350 and thought my old 12Bolt would be OK. I beat on it for a few years and stuffed the pinion gear through the bottom of the carrier.
Don't put off upgrading your rear end and rebuilding the stock 700.
00 for engine/install-blown-diff-22.jpg
Old Mar 11, 2010 | 10:33 PM
sethteef's Avatar
Car: 88 firebird
I would be planning redoing the drivetrain within a year if things go like planned.
Old Mar 11, 2010 | 10:35 PM
Gregzz4's Avatar
I just fixed the Pic in my previous post
Have a look
Old Mar 11, 2010 | 11:29 PM
Irockz's Avatar
The cam you listed earlier is far from stock.I would lean towards an XE268 Comp,vortec heads,and a Performer RPM intake.I would say your still going to be dealing with hood clearance problems with the Holley,but if your willing to deal with that,it's the right choice in a carb,although a 650cfm may better serve your needs.I'd run a dished piston with those heads to keep compression in check,should easily make a 350hp engine that will be fun to drive every day.
Old Mar 11, 2010 | 11:51 PM
five7kid's Avatar
Attachment 194882
12-bolt???
Old Mar 12, 2010 | 11:09 AM
sethteef's Avatar
Car: 88 firebird
Thanks for info on this. Will it still run around the same amount price wise? I saw that a non chrome rpm intake would be cheaper than the victor jr but I dont know about the other parts.
Old Mar 12, 2010 | 09:39 PM
Gregzz4's Avatar
Originally Posted by five7kid
12-bolt???
Yes 12-Bolt.
You'll see I'm still driving my Truck
Old Mar 12, 2010 | 10:43 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
with a performer rpm you will have hood clearence issures but its easily fixed. ive got a power buldge hood an i just had to cut a small section of hood bracing out. not a big deal in my opion. i run 10:1 compression in and 93 never gives me a fit on iron heads. and that xe268 cam is milder than mine so you should be fine.
id say all that would make for a fun dd
Old Mar 13, 2010 | 01:28 PM
sethteef's Avatar
Car: 88 firebird
If I buy a cowl hood will I still have clearance issues? If I do I found where I can get one for about 400.
Old Mar 13, 2010 | 06:14 PM
ziggy89's Avatar
Engine: 383
no a cowl would take care of alot of you clearence issues. depending on wat you want. look into glasstek they in naperville 4inch cowls run bout 420 bucks. free shiping if you go get it.
Old Mar 13, 2010 | 08:58 PM
sethteef's Avatar
Car: 88 firebird
There is a place closer to me that charges $414 for a pickup in plainfield. For the same style hood. So what little I had already saved so going to that first. Prolly get it like couple weekends.
Thanks for the info.
Chevykid810
Sep 28, 2015 12:57 PM
tuningnewb
Sep 23, 2015 07:06 PM
ULTM8Z
Sep 16, 2015 09:15 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
Dialed_In
Aug 20, 2015 01:45 PM
