How do you pull your engine?
Old Mar 11, 2010 | 08:45 PM
Weffy's Avatar
Car: (sold 85' IROC Z28)
Engine: (89' 305 TPI)
Transmission: Looking for a classic chevy
Do you pull it with the tranny attached... OR do you pull just the block then drop the tranny?
It seems like an easy job to just pull the tranny still attached to the motor if you have a leveling attachment for your hoist. Then again, pulling the motor straight up and out is, well... pretty straight up and out foreword.
Old Mar 11, 2010 | 08:54 PM
84z .....'s Avatar
Car: Blue 84 z28/Cyber 2010ss/rs
Engine: Dart headed, 12:1 355- 510/530 cam
Transmission: TKO 600 Lakewood Bell
Axle/Gears: Richmond 410 Spooled
Re: How do you pull your engine?
jack the front of the car as high as possible and simple undo the tranny X member bolts after remove the engine mounts. Take ur time and wiggle that motor out . At leaset that how i did it twice.
Old Mar 11, 2010 | 08:57 PM
Weffy's Avatar
Yeah that does seem like the logical decision considering that the trans is getting replaced. No point in fidgeting with the bell-housing bolts just to remove it separately.
Did you use a leveling thing, or just a chain?
Old Mar 11, 2010 | 09:02 PM
84z .....'s Avatar
if u have that leveling thing use it it makes it alot easier when u about to get it over the upper rad support.
Old Mar 11, 2010 | 09:05 PM
Weffy's Avatar
Yeah, I don't have one, but hey I'll just buy one then return it haha.
Pocket's Avatar
Car: 91 Trans Am
Out the top or out the bottom, both are simple for 3rd gens
84z .....'s Avatar
Old Mar 11, 2010 | 09:06 PM
Weffy's Avatar
Bottom??? How does that work?
Old Mar 11, 2010 | 09:10 PM
84z .....'s Avatar
unbolting the k member as a hole .
Old Mar 13, 2010 | 08:45 PM
Weffy's Avatar
Well, I ended up just leaving the tranny in for now, and out the top
The bolts on the bell housing were surprisingly easy to get to, even the top ones.
What I didn't expect though... I had to take the whole front end off almost to get the hoist to reach the engine.
But its out now, with little to no casualties.
Old Mar 13, 2010 | 08:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I found it easier to just unbolt the tranny from the motor and then get the motor out. When putting it back in, i move the tranny back a few inches, drop motor in and then move tranny forward.
Old Mar 13, 2010 | 08:58 PM
Weffy's Avatar
Did it always line up?
I think I'm going to put the motor in with the tranny attached. I'd rather fidget with it fitting from the top, and not from under the car with no leverage.
Old Mar 13, 2010 | 09:04 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
I just pulled my 327 out the other day, ended up pulling the engine out the top with the hood removed and just dropped the trans out the bottom. Took all of 4 hours and only 6 beers.
Old Mar 13, 2010 | 09:06 PM
Weffy's Avatar
Haha yeah it took me a good 6 hours of disconnecting/logging then another 6 just to get it out.
Pictures for fun
Old Mar 15, 2010 | 08:24 AM
88Cvert's Avatar
Car: ,89 iroc z
Engine: 350 tpi
Transmission: ,700r4
Axle/Gears: 3;27 9 bolt
wasnt that car on craigs list a lil while ago?
Old Mar 15, 2010 | 08:29 AM
Weffy's Avatar
Haha yeah, picked it up 2 or 3 weeks ago. Did you look at it? But, yeah he listed it as "the rods are knocking slightly" I get there it sounded like someone left a spoon in the oil pan, a fork in the valve cover, and a knife in a chamber. Not to mention on the drive home the wheel nearly fell off.
Old Mar 15, 2010 | 08:45 AM
88Cvert's Avatar
Car: ,89 iroc z
Engine: 350 tpi
didnt go and look at it but sure did see it on CL.
Old Mar 15, 2010 | 08:49 AM
Weffy's Avatar
Yeah, hey you don't happen to have an oil pan layin' around do yah?
Old Mar 15, 2010 | 08:57 AM
88Cvert's Avatar
Car: ,89 iroc z
Engine: 350 tpi
nope , got some on motors but none not being used .a new replacement shouldn't be that much .so what all are you doing to the car?
Old Mar 15, 2010 | 08:59 AM
Weffy's Avatar
Just swapping the motor for a fresh 305. This cool stubborn aluminum oil pan is giving me the hardest time though haha. its gettin done... slowly...
Old Mar 15, 2010 | 09:03 AM
88Cvert's Avatar
Car: ,89 iroc z
Engine: 350 tpi
hey well let me know if you need a hand or something .ive done quite a few engine swaps in these third gens .
Old Mar 15, 2010 | 09:07 AM
Weffy's Avatar
Will do, I'll probably need a bunch of help hooking the top end back up. So many wires that I'm sure Ill have no clue where to connect.
Old Mar 15, 2010 | 01:02 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I alwys pull them without the trans. Just make sure you have enough room to get the trans out from under the car if you need to. I have a transmission jack so it's real easy to move it around and support it while pulling the motor.
It ws a bit of a pain dropping the motor in with the bellhousing/clutch attached, so doing it with a whole trans attached would irritate the crap out of me Im sure.
Old Mar 16, 2010 | 01:57 PM
Mr.Goodwrench's Avatar
Car: 84 Z28 HO
Engine: 305 HO
Transmission: auto
Just pulled the 305 out on sunday engine and trans all together took 3.5 hours, all in all it was very easy just pulled the hood off and the trans crossmember and I used a liftplate where the carb goes, worked very well.
Old Mar 16, 2010 | 03:03 PM
Pocket's Avatar
Car: 91 Trans Am
Unplug the ECM, and C100, disconnect the trans lines, disconnect the coolant lines, remove the radiator hoses, unbolt upper strut nuts, disconnect the front brake lines, remove Y-pipe, unbolt crossmember and K-member
Lift the body off the whole front suspension. Took me about an hour. No reason it should take more than two
Going back in was simple too, just reverse order. Use the front wheels to roll the assembly around. I had access to a lift, but a cherry picker can be used in the same fashion
Old Mar 16, 2010 | 03:59 PM
Weffy's Avatar
Did you just leave the top end mostly connected and pull the harness with it?
Old Mar 16, 2010 | 06:20 PM
Pocket's Avatar
Car: 91 Trans Am
I took the breather pan off, thats it. Harness came with the engine
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
