mounting old brackets to new heads??
hello!!
were working on our 91 rs engine swap. we want to put the origional brackets. on passenger side of block ac, smog pump, tensioner bracket.
the origional head had 3 bolts at the front. our edlebrock victor jr. alum. head has 1. i need 1 more bolt hole to tighten up the bracket.
has anyone else here ran into this?? does anyone here know if i can drill and tap a hole where i need it?? please comment!!! thanks very much!!!
Transmission: 4L80E/4L80E
Shouldn't be a problem. Don't drill them any deeper than necessary.
Might not hurt to call Edelbrock and get their take on it.
Re: mounting old brackets to new heads??
thank you! thats what i did, i found a tech support line for edelbrock. that man said the same. at worst i would hit a water jacket.
i drilled & tapped it 1/2 inch as much as i could tell. i got 6 complete turns with 3/8 bolt and gooped it up good with marine grade thread sealent sticky gunky stuff.
got my fingers crossed!!!!!!!! hope to have it running in a month and we'll see if it leaks
thanks again!!!!
thanks again!!!!
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
