HELP PLEASE!!! want to take my 3.1 to a 350 4 bolt main
Car: 91 RS, 84 Z28, 85 Iroc-z
Engine: 3.1L, 350 4 bolt, 350 TPI
Transmission: 700R4, 700R4, 700R4
Axle/Gears: 3.23, Unknown, Unknown posi
I would just like to know what all I would need to replace as in radiator, transmission (700R4) and other stuff like that. What all would I have to do to the fuel pump since I'm planning on switching to carbed on this swap? Also I would like to put some sort of posi rear in. What would be the cheapest/easiest way to do that?
Thanks guys
Thanks guys
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: HELP PLEASE!!! want to take my 3.1 to a 350 4 bolt main
install V8 motor mounts and older model carb sending unit
so would you know if the tranny or the rad will still work?
thanks
thanks
if you have a 700r4 it will work. this is what i do to see if parts will interchange. go to www.autozone.com, choose your vehicle and part, then see if the car with the other options have the same part number.
thank you... Do you know what any good heads for it? or any good cams?
Transmission: 4L80E/4L80E
A 3.1 TH700 won't work with a V8.
The 3rd gen 3.1 radiator is the same thing as a 3rd gen V8 radiator.
is the TH700 different than the 700r4? thanks
is the TH700 different than the 700r4? please reply
"TH700" is short for "TH700R-4".
Both the V6 and V8 4-speed overdrive transmissions used in 3rd gen f-bodies are TH700R-4's, but the bell housing and internals are different. The main issue is you can't bolt a 3rd gen f-body V6 TH700R-4 to a V8.
Ok thanks... Would a th350 from a 76 Nova bolt right up?
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
ur best bet is to just go find a v8 style 700r4 dont waste ur time on a th350
ambainb
Apr 25, 2016 09:21 PM
