Swapping heads?
Old Apr 7, 2010 | 12:57 AM
sk8r fer life's Avatar
Car: 1990 camaro rs
Engine: 305 tbi
Swapping heads?
Ok just wonderng can I take the heads off my 84 vette and put them into a LT1, both engines need to be rebuilt but the LT1 has flooded heads so they need to be replaced, Or will they not work...
Thanks Tim
Old Apr 7, 2010 | 06:23 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Swapping heads?
short version: no, its not as easy as just swapping the heads
Old Apr 7, 2010 | 09:28 AM
Car: 1990 camaro rs
Engine: 305 tbi
Re: Swapping heads?
I'm not asking if it will solve the problem I just want to know if the heads will fit....
thanks tim
Old Apr 7, 2010 | 10:29 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
They will bolt on, but the water passages won't match.
Old Apr 7, 2010 | 10:43 AM
Car: 1990 camaro rs
Engine: 305 tbi
Re: Swapping heads?
oh, ok thanks for the help
Old Apr 7, 2010 | 11:24 AM
3rdgenmaro's Avatar
Car: 88 IROC
Re: Swapping heads?
better short version
Old Apr 8, 2010 | 10:12 AM
85 lg4's Avatar
Car: 89 TA
Engine: Fast !!
Transmission: slipinslide auto
Re: Swapping heads?
hey !! WHAT HAP[PENED WITH YOUR MOM AND MY IROC? let me know asap I got a few others interested just waitng to here back from you as I promised it to you first
Old Apr 8, 2010 | 11:46 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Swapping heads?
What do you mean by "flooded heads" and why cant they be rebuilt with the engine?
Rebuild the LT1s and if for some reason they're toast, buy a cheap set of used heads to get cleaned up. Do a search for LT1 heads on a SBC and youll see how much is required to get them to work. The reverse is true to put the TPI heads on the LT1. Why would you want to anyways? 84 C4 means crappy irons
xkingcodex
Feb 12, 2020 07:43 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
