motor mount conversion for pontiac V8
Old Jun 29, 2010 | 09:36 AM
j dezzy's Avatar
Car: 87 TA
Getting everything together to drop a pontiac 400 into my trans am but I can't find anyone who has conversion motor mounts. I thought I read that motor mount location will be different for a pontiac motor...Am I wrong? Will it bolt to the stock SBC motor mounts in their current location? If not does anyone know where I can get some mounts for this application? Thanks
Old Jun 29, 2010 | 11:46 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: motor mount conversion for pontiac V8
https://www.thirdgen.org/forums/engi...-v8-swaps.html
Old Jun 29, 2010 | 02:08 PM
j dezzy's Avatar
Car: 87 TA
I read that thread and there is very little reference to motor mounts. Other than a link to a place called indian conversions. A link that is dead. Ive done my reading, this is the only thing im fuzzy on. Id rather buy direct bolt on mounts instead of welding some in.
Old Jun 29, 2010 | 02:37 PM
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
at this time no one makes them. you have to modify/make them yourself.
Old Jun 29, 2010 | 03:18 PM
j dezzy's Avatar
Car: 87 TA
thanks. thats all I needed to know.
Old Jun 29, 2010 | 03:33 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Seems to be one of the projects that the builder is out having so much fun they never check back or it was a bust or they wrecked.
Seen a couple of Buick 455 build 3rd gen's and they always go MIA at the end.
Old Jun 29, 2010 | 06:52 PM
j dezzy's Avatar
Car: 87 TA
I'll be sure to post my results and pictures after I get the engine in.
Old Jun 29, 2010 | 07:12 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well that's about as far as they get, I got engine pics of both, then its like they hit 88MPH and went back in time
Old Jun 29, 2010 | 07:15 PM
BlwnSS's Avatar
Car: 1999 Formula Hardtop
Engine: 6.2 forged ls3 Procharged
Transmission: t56 Magnum
Axle/Gears: midwest chassis fab 9/3.50
bullshit that the mounts arnt made anymore , ihave a 400 an 455 just sitting and no mounts . not like the mounts are holding me back , its money but still come on chief many horses make them again .They were only like 79 bucks.
Old Jun 29, 2010 | 07:56 PM
j dezzy's Avatar
Car: 87 TA
Every time I try to go to the chief many horses web site I'm redirected to some BS search engine.
Old Jun 30, 2010 | 08:34 AM
72vega's Avatar
the site doesnt work anymore. http://www.chiefmanyhorses.com/ check for yourself. i also looked on some other pontiac parts sites also, nothing.
Old Jun 30, 2010 | 09:34 AM
j dezzy's Avatar
Car: 87 TA
I just found some Indian Adventures conversion motor mounts at pontiacgroup.com. They're $90 though! I can't see paying that much for $5 worth of metal. lol. I still might just make my own. Here's the link to the block mounts, http://pontiacgroup.com/engineparts/blockpart/10776.htm
Old Jun 30, 2010 | 12:27 PM
72vega's Avatar
thanks for the link!
Old Jul 4, 2010 | 10:09 AM
j dezzy's Avatar
Car: 87 TA
What do you guys think of these? Says they'll allow you to put any motor in any vehicle...
http://www.summitracing.com/parts/TRD-4227/
Old Aug 29, 2010 | 12:35 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Whatever it may say, those are solid mounts for a chevy engine to go in any vehicle. Those mounts wouldn't fit my Buick, Olds, or Pontiac engines.
I think you'd be best off using late 2nd Gen mounts to put your engine in. It will get you the closest and if you have to redrill or slot the crossmember for your lowers then so what?
Old Aug 29, 2010 | 01:00 PM
j dezzy's Avatar
Car: 87 TA
I actually ended up using a conversion kit from yearone that I had lying around. I used the engine mounting brackets from the RW81 kit HERE. And made my own engine support bars. I also got rid of the stock motor mounts and bolted up a pair that were made for a 2nd gen, they're a tiny bit different and it made things just a little easier. I've been taking pictures as I go and will be posting a thread on the whole swap once the engine is compltete. I didn't want this to be a big ordeal since I'm trying to get the restoration on my 79 complete. So now I've just been shifting money back and forth between the 2 car, so it's slow going.
Old Aug 29, 2010 | 03:22 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
So its in?
Where are the pictures???
Old Aug 29, 2010 | 03:25 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
If I was just purchasing parts and not fabbing them up myself, I would start with this kit:
http://www.yearone.com/serverfiles/f...hid=413AG51516 (the TB389M at the bottom)
The RW81 kit for the Olds has the plates that are already drilled so that you can move the engine brackets to several different positions if you were using an Olds V8
The mounts and frame brackets are for the 70's Pontiac V8, with the bars already made to bolt to the side of the older 60's Pontiac blocks. You can use that flat plate to re-drill the holes for the mounts and then you can put those engine brackets wherever you want to match your rubber lowers. You can bolt your Pontiac rubber lowers to the frame in the same place that the Chevy lowers go and adjust the uppers to sit on them. That should maintain the proper height of the engine as well.
Old Aug 29, 2010 | 04:05 PM
j dezzy's Avatar
Car: 87 TA
that's the one I had in mind when I was making up my own adapters. I didn't want to sink all that money into something that would take me an hour to fab up in my garage. But if you've got the money that is definatly the way to go.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
