Does anybody know if this is a 305 or 350??????
We started a project about a week ago, the motor isnt the original motor, the numbers are as follows on the block, K0309PNM can anybody tell me what the CID is for this motor. Thanks.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Does anybody know if this is a 305 or 350??????
What's the casting number behind the drivers side head?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I see no PNM suffix number listed. Are you sure that's the correct letters?
Car: '89 Trans Am
Axle/Gears: 9 bolt 3.23 posi disks
If the heads are off it you can usually tell just by looking at the cylinders.
Yeah, whats weird is, that it says its a roller 305, when I pulled it apart, it had a flat tappet cam and lifters. ?? Any insight on that?? Im really confused. I think as stated on another post, Im going to just get a 350 and start that build instead I was really hoping the motor in it was a 350. poop
Transmission: 4L80E/4L80E
Trucks had flat tappet cams, and people often replace roller cams with a cheaper flat tappet.
Ok, I didnt know you could do that. I thought you must stay roller if it was roller. Wonder if it would be benificial to get a roller set up, or still screw the whole thing and get a 350?
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
SBCs designed for roller cams also had provisions for flat tappet style cams. The reverse is not true, though retrofit kits do exist to convert from flat tappet to hydraulic roller cams. Though I am uncertain as to how well they work.
Car: 87 IROC L98
Any flat tappet engine can be converted to roller cam. You just need to use roller lifters with a link bar because the lifter bores don't have alignment slots to hold OEM style roller lifters. The link bar between 2 lifters keeps them in alignment.
Thanks for the info. So that explains why he had new push rods from sealed power in the motor. He prob had to get a different length cause he went flat tappet. Well, I stayed with a flat tappet cam, but have different rockers, wonder if I can use the push rods he has? Would different rockers matter to the push rod length?
Engine: 383 Carb
Transmission: 4L60
Probably not, but you should measure to see.
