Standard O.P.
Old Dec 9, 2010 | 06:46 PM
ianclark's Avatar
Standard O.P.
When you swap a motor into another later model vehicle is it common to swap the harness and computer with it?
Old Dec 9, 2010 | 07:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Standard O.P.
It depends what the original engine was, what the new one is, and how much you're swapping.
Old Dec 10, 2010 | 02:41 PM
ianclark's Avatar
Re: Standard O.P.
I am pulling an 83 CFI engine and tranny together and am Putting it into a 92 F body
Old Dec 10, 2010 | 04:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Standard O.P.
How much of it are you swapping? Just the short block? Long block? Intake too?
Old Dec 10, 2010 | 05:12 PM
ianclark's Avatar
Re: Standard O.P.
Im swapping all of it engine and tranny complete and dropping it into the 92 body.
Old Dec 10, 2010 | 05:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Standard O.P.
If you're swapping the CF induction system too, then absolutely you'll need the harness and ECM to make it work.
Old Dec 10, 2010 | 05:20 PM
ianclark's Avatar
Re: Standard O.P.
yes I thought so. So ive begun pulling the harnesses. The c100 pinouts are of corse different any idea where to get an 83 CFI c100 c207 pinout diagram? Thanks for responding by the way.
Old Dec 10, 2010 | 05:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Standard O.P.
Check an 83 factory service manual.
Old Dec 10, 2010 | 05:49 PM
ianclark's Avatar
Re: Standard O.P.
ok will do can I just swap the prom itself or do I need to swap the whole ECM?
Old Dec 10, 2010 | 06:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Standard O.P.
The whole thing. The ECMs are completely different.
Old Dec 10, 2010 | 08:28 PM
ianclark's Avatar
Re: Standard O.P.
Yep thats what I thought now I am planning to repin the 92 c100 to accept the 83 harness and then on down the line to the ECM. Am I missing any thing?
Old Dec 10, 2010 | 08:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Standard O.P.
Why repin when you could replace the harness on both sides?
Old Dec 10, 2010 | 08:38 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Re: Standard O.P.
Indeed you could just replace the dash harness as well, but I believe you would have to also swap the cluster and mechanical speedo stuff?
Old Dec 10, 2010 | 08:40 PM
ianclark's Avatar
Re: Standard O.P.
Both sides? you mean all the wiring or what.
Old Dec 10, 2010 | 08:42 PM
ianclark's Avatar
Re: Standard O.P.
Yeah I would think that would be much more intensive, Right?
gixxer92
May 18, 2017 11:20 AM
Fronzizzle
Feb 9, 2017 09:31 AM
Gunner242
Dec 25, 2015 04:49 PM
1992Z28!
Nov 19, 2015 07:33 AM
Bigold4x4
Sep 28, 2015 05:21 PM
