1985 camaro HO
Old Dec 27, 2010 | 10:18 AM
mkingan's Avatar
1985 camaro HO
i am in the process of aquiring a 1985 camaro IROC HO. this is the first project of this type so i am a little unfamiliar with it. It comes with no motor (previous owner does not have it and didnt have a clue what was in it). It still has the factory 5 speed in it. I am looking for a replacement motor. what are my options for an easy replacement. i have no idea if a standard 305 carb or tbi was installed i it. if it was just carbed will a tbi bolt right in? any ideas or direction would be most helpful. thanks
Old Dec 27, 2010 | 10:48 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 1985 camaro HO
An IROC could only have come with a 305 of some sort. 1985 was the first year that the TPI LB9 was available, but if the car was badged as an H.O., then it would have had the carbureted L69. Any SBC block will bolt in with minimal effort, but putting a fuel-injection setup on top will require some more work.
Old Dec 27, 2010 | 11:06 AM
mkingan's Avatar
Re: 1985 camaro HO
ok. yes it is badged with the "HO" so just a standard carbed SBC should bolt up to the trans and bolt right in? (mounts and such)?
Attached Thumbnails 1985 camaro HO-img_4780.jpg   1985 camaro HO-img_8719.jpg   1985 camaro HO-img_2834.jpg
Old Dec 27, 2010 | 11:10 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 1985 camaro HO
Any SBC will bolt up. Getting what's on top of it to work just takes a little more effort if you don't use a carb.
Old Dec 27, 2010 | 11:31 AM
mkingan's Avatar
Re: 1985 camaro HO
ok thanks now just got to find one to drop in.
Old Dec 29, 2010 | 08:49 PM
oldtimer's Avatar
Re: 1985 camaro HO
Looks like you have an 83 or 84 Z28 on your hands, not an 85 IROC, just fyi. You will need a bellhousing and clutch for this thing, too, it would appear. The 83 had a mechanical clutch, while the 84 switched to hydraulic actuation. Dropping a motor in it will be easy, but the small things can make or break something like this. How are emission regulations in your area? Will the car be legal, and can you get a tag if you just toss a motor into the car? Thanks, Rudy.
Old Dec 29, 2010 | 09:10 PM
mkingan's Avatar
Re: 1985 camaro HO
thanks for the info. i have to get the vin number to find out whats up. i was just going ton what was told to me and had a buddy go down and talk to the guy. i also found out that he has the org motor running in his pickup and said he would sell it with the car. looks like going to take a trip out there find out the details.
Old Dec 29, 2010 | 11:43 PM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
Re: 1985 camaro HO
dont waste ur money on the 305, save up and get a 350 a ton more power potential
Reddeath210
Oct 6, 2015 08:20 AM
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 17, 2015 02:52 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
Fronzizzle
Aug 9, 2015 01:15 PM
