86 305 tpi to 88 vette 350 tpi
Old Mar 4, 2011 | 10:55 PM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
i just sold my original motor a 1986 305 tpi and i am gona buy a 1988 corvette motor with aluminum heads its a 350 tpi my question is if i sell my stock wiring harness from my trans-am will the wiring harness that comes with the corvette will it fit my trans-am
Old Mar 5, 2011 | 12:25 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 86 305 tpi to 88 vette 350 tpi
Originally Posted by black-bandit
will the wiring harness that comes with the corvette fit my trans-am
Doubt it
Engine connections for TPI will be the same but firewall connections most likely different
Could be made to work but .......
Smart person would sell the Vette harness with your old motor and keep the harness you know FITS your car
Old Mar 5, 2011 | 12:49 AM
DiabloWS6's Avatar
Originally Posted by vetteoz
Doubt it
the reason im selling my oem harness is to reach the total for the corvette motor im a couple hundred dollars short and selling my harness would put me that much closer to it but u mentioned it could fit but firewall connections are different could u splice those coonections and make them a lil bit longer to fit the appropaite lenght to make them fit in my trans-am stock locations and after shrink wraped were a spliced or if thats not the way what is alternate option while still using the corvettes harness
Old Mar 5, 2011 | 07:16 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Why would you take out the correct, perfectly good harness you already have and replace it with one you have to buy that requires playing around with to work
Save some $$$ and buy the Vette motor without the harness ,you don't need it
or get the person buying your engine to buy the Vette harness from the owner at same time as you buy engine so everyone is happy
Old Mar 5, 2011 | 12:46 PM
DiabloWS6's Avatar
the problem is the corvette motor will come with the harness even if i dont want it and my oem motor is already sold ....i asked one of my instructors from school and i asked him about the harness and said it could be possible to use the harness from the corvette and use it on my trans-am and where the corvette harness needed to be longer i could splice wire into it to make it reach and shorter where it needed to be shorter i know its dumb to sell my harness but im not gona find one these motors that are near by ohters i would have to travel far or have it shiped but my situation is complicated there are other factors involved that are personal in regards to me doing this and would not like to say but i cant hope u understand but it is what it is......if there is more advise or tips on this topic please let me know
Old Mar 5, 2011 | 05:40 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Probably not because the only person who would use a non 3rd Gen harness would be someone converting a non injection car to EFI and even then they would most likely buy a used 3rd Gen harness to make life easier .
Anything is possible , just going to take some work on your part. Need to get circuit diagrams for both cars and match wires up
Old Mar 6, 2011 | 02:38 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Its not a question of the harness having some wired shorter and some wires longer. The problem will be were the harness connects to the firewall. The plugs will most liekly have pins in different locations/some not there at all/and some that dont need to be there. That would be a pain to fix. You either need to find a way to keep the stock harness, or get a used 3rd gen harness to replace it. The vette harness is pretty much useless to you.
Old Mar 6, 2011 | 07:50 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Put a deposit on Vette engine
Get Vette harness
Sell Vette harness with your engine
Pay balance owing on Vette motor
Everyone happy
Old Mar 8, 2011 | 03:46 AM
DiabloWS6's Avatar
i ran into another problem the 88 corvettes had the pass key if they did which i think they do and its different for the camaro and firebird how would u get it by passed since i have an 86 trans-am
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
